10-Bit Color in El Capitan: A sign of things to come in FCPX?
COW Forums : Apple Final Cut Pro X Debates
Nicholas Zimmerman
on Nov 5, 2015 at 11:08:47 pm
I figured you guys might be interested in this: 4K and 5K iMacs Support 10-Bit Color Depth on OS X El Capitan & Apple Is Paving the Way for 10-Bit Color with Its Latest OS X Update
So we now have support for 10-bit color depth native in the OS (finally!). Given that Final Cut Pro X already supports 10-bit video via hardware IO, I feel like it's got to make an appearance in the viewers on this next update. From what I've read on Mac Rumors and No Film School, it's currently supported on the Mac Pro, some 15" Retina Macbook Pros and Retina iMacs. I haven't moved on from 10.10 yet (damn you Media Composer), but this has me really excited as both of my displays are 10-bit panels. This is also great news for the Adobe guys, as this would bring the OS X apps back to parity with their Windows counterparts. At least it will when Adobe gets around to enabling it, which shouldn't be too long given their recent track record. Currently it's only supported in Photos and Preview, but I would be very surprised if we didn't see numerous creative apps taking advantage of this very soon.
On a side note, I'm curious if we'll see Metal support added in Apple and Adobe's next updates. We know it's eventually headed to Adobe, and of course Apple will utilize it. It's much more a question of when rather than if. What sort of improvements can we expect? Does anyone know if using it in the FxPlug framework would add any measurable improvements to existing plugins? Will we see it used to speed up the sometimes slow UI animations in FCPX?
________________________________________
NickZimmerman.net
Dennis Radeke
Re: 10-Bit Color in El Capitan: A sign of things to come in FCPX?
on Nov 6, 2015 at 12:21:44 am
[Nicholas Zimmerman] "This is also great news for the Adobe guys, as this would bring the OS X apps back to parity with their Windows counterparts."
Yes.
Brooks Tomlinson
on Nov 9, 2015 at 8:05:06 pm
how does one test to see if you are getting 10-bit video out of your i/o (aja or black magic)?
Brooks Tomlinson
"I dream in 32bit float"
Robin S. Kurz
on Nov 9, 2015 at 8:37:33 pm
[Brooks Tomlinson] "how does one test to see if you are getting 10-bit video out of your i/o "
9 out of 10 times you won't notice in normal use cases and it's actually considered to be a bit of a fallacy by many. Even if the owners of 10bit systems won't generally want to admit to it. ;) But whether you have 10bit output is obviously only relevant if you in fact also have a 10bit display, the needed GPU and most of all appropriate drivers. Do you?
But you can find a 10bit test image here for example: http://bit.ly/1kH4muc If you see obvious banding, it's not displaying 10bit. Raise the gradient steps minimally and already you won't see any banding in either case.
- RK
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
Walter Soyka
on Nov 10, 2015 at 4:04:08 pm
[Robin S. Kurz] "9 out of 10 times you won't notice in normal use cases and it's actually considered to be a bit of a fallacy by many. Even if the owners of 10bit systems won't generally want to admit to it. ;)"
I'm stoked that Apple has finally implemented deep color. I think that a 10-bit display pathway is really important if you've profiled your monitor and are trying to using color management for accurate color on your GUI. Applying a display LUT on an 8-bit pathway is practically guaranteed to introduce visible banding where none exists in the source image.
To head off any argument, I am happy to stipulate that color management on the desktop is not a normal use case.
Of course, knowing of Brooks by reputation, I'd suggest he's not exactly pushing the normal use case either. Brooks, as far as I know, Smoke and Flame are 8-bit on the GUI only, even on Linux with 10-bit capable Quadro cards and Eizo displays.
SCRATCH 8.4 supports 10-bit display on El Capitan. They're the first ones out of the gate that I know of.
Walter Soyka
Robin S. Kurz
on Nov 10, 2015 at 6:36:52 pm
[Walter Soyka] "SCRATCH 8.4 supports 10-bit display on El Capitan. They're the first ones out of the gate that I know of."
Good to know. Thanks for the heads up! They'd be the first that I know of also.
- RK
Walter Soyka
on Nov 12, 2015 at 2:36:17 pm
And Resolve 12.1, updated today, is the second.
Walter Soyka
Robin S. Kurz
on Nov 12, 2015 at 5:01:19 pm
Ooh. Nice.
Brooks Tomlinson
on Nov 16, 2015 at 10:15:12 pm
Thanks Walter you are exactly correct :), I was looking for definitive proof. The black magic guys said you can run it into ultra scopes and find out, but couldn't find my dvi adapter. I'll have to test that out sometime soon.
But I did find out by trial and error exactly what Walter just said.
Also in my quest to find out if mac can out put a 10-bit signal at all (hd-sdi, a respected college says it can't do 10 bit at all) I found out that no matter what I did in premiere on mac. The output was always 8-bit.
I had my Pablo Rio feeding a gradient into sdi 1, and my mac feeding sdi 2. I couldn't get them to match till I used the blackmagic media program. Then my two displays matched perfectly.
Anyone know what I'm missing in premiere?
I want to see what resolve and the 10-bit option looks like on the new 5k mac!
Brooks Tomlinson
Brooks Tomlinson
on Jan 11, 2016 at 3:32:41 pm
Okay, took a little bit, but Found out for sure you can have 10-Bit export from mac thru I/O. I ran a 10-bit signal from my pc, and mac thru the same Flanders monitor. Then just switched from sdi1 to sdi2. It matched.
Also, I called blackmagic and they confirmed as well.
Brooks Tomlinson
Shane Ross
on Jan 11, 2016 at 7:43:19 pm
IO devices like the AJA Kona and IO cards have been 10 bit for quite some time. WELL BEFORE El Capitan came out. The OS being 10-bit and IO cards outputting 10-bit from the NLE have zero connection. FCP 7 output 10-bit video via IO. As did FCP 6....it's nothing new.
Shane
Little Frog Post
Bill Davis
on Jan 11, 2016 at 10:02:37 pm
[Shane Ross] "IO devices like the AJA Kona and IO cards have been 10 bit for quite some time. WELL BEFORE El Capitan came out. The OS being 10-bit and IO cards outputting 10-bit from the NLE have zero connection. FCP 7 output 10-bit video via IO. As did FCP 6....it's nothing new."
Well.... Isn't this kinda like discovering that YOUR new vacation property has a beautiful stand of wildflowers that come out every year - something that makes you smile - and then telling your neighbor how nice it is, only to have them say "Well, it's no big deal - WE've had wildflowers for the last five years too.
It's kinda NOT the point.
While it's lovely that you had this before. It's STILL really nice that Brooks gets to ALSO have it in the workflow he's living in and prefers RIGHT NOW.
Know someone who teaches video editing in elementary school, high school or college? Tell them to check out http://www.StartEditingNow.com - video editing curriculum complete with licensed practice content.
Shane Ross
on Jan 11, 2016 at 10:10:13 pm
[Bill Davis] "While it's lovely that you had this before. It's STILL really nice that Brooks gets to ALSO have it in the workflow he's living in and prefers RIGHT NOW.
I kinda feel like Glenda the Good Witch here..."Ohhh, but Brooks, you've had this ability ALL ALONG!" Because he has. 10-bit via IO has been there for a long long time, I just needed to reiterate that point...As Nicholas said in his first paragraph, "Given that Final Cut Pro X already supports 10-bit video via hardware IO, I feel like it's got to make an appearance in the viewers on this next update."
So where you NOW see it is on your computer display. If you have a 10-bit computer monitor, that is.
Brooks just seemed to be excite that he now got it over IO...just saying, it's pretty much always been there via IO.
Shane
Little Frog Post
Walter Soyka
on Jan 11, 2016 at 10:14:34 pm
[Shane Ross] "Brooks just seemed to be excite that he now got it over IO...just saying, it's pretty much always been there via IO."
There was some (legit) question about whether Premiere was actually outputting 10-bit video with IO cards like it was supposed to be:
https://forums.creativecow.net/thread/3/935209
https://forums.creativecow.net/thread/3/968552
https://forums.creativecow.net/thread/3/947017
Walter Soyka
