Importing 5.1 Surround Sound
COW Forums : Apple Final Cut Pro X Debates
Bridget Cook
on Sep 3, 2015 at 12:11:49 am
I'm making a short film. The sound guy did it in 5.1 surround sound. I'm editing in FCPX. He sent me 7 files - The C, L, LFE, Ls, R, Rs. He also sent a file called 5.1 Final. To export the movie with 5.1 surround sound, do I need to import the 6 individual channels to my project in FCPX or can I just use the single 5.1 final file? Not sure if this helps but the 5.1 final file is is 745MB while the other six files are 124MB each.
Charlie Austin
Re: Importing 5.1 Surround Sound
on Sep 3, 2015 at 2:29:44 pm
Is it the final mix for your film? If so, just import the 5.1 version.
~ My FCPX Babbling blog ~
~"It is a poor craftsman who blames his tools."~
~"The function you just attempted is not yet implemented"~
Bridget Cook
on Sep 3, 2015 at 9:10:38 pm
Yes it is the final mix. So I just use that one large file? Thank you for your help.
Charlie Austin
on Sep 4, 2015 at 5:48:22 pm
[Bridget Cook] "Yes it is the final mix. So I just use that one large file? Thank you for your help."
Yep, that should be fine... give it a unique Role and make sure you set the the export to Roles as Multitrack Quicktime Movie and set the format to surround. :-)
