best way to blend 24fps & 25 fps footage w/ one audio track?
COW Forums : Apple Final Cut Pro X Debates
sean miller
on Sep 2, 2015 at 4:22:09 pm
Hi guys,
I have an interview, seperate audio track, two angles. One camera recorded on 24 fps and the 2nd on 25 fps.
Whats the best approach here? - Remove frames from the 25fps video?
Bret Williams
Re: best way to blend 24fps & 25 fps footage w/ one audio track?
on Sep 2, 2015 at 5:26:40 pm
The most important part is what format you have to deliver. If it's 24p then put the 25 in a 24p. Or vice versa. Probably won't even notice the drop (or repeated) frame since it's an interview.
