Resolve 12 Beta 2 improved performance
COW Forums : Apple Final Cut Pro X Debates
Morten Ranmar
on Aug 4, 2015 at 8:29:28 pm
I have "upgraded" to todays Beta2 release of Resolve 12, and can testify that performance has already improved since the last beta. With Beta1 there was performance issues with heavy grades and transitions, which I do not see as much now. For example a clip with 2 nodes of color correction (including a single Power Window) appears to play back in real time (1920 x 1080). Of course throwing in additional effects slow down the performance - but Resolve does offer a single button to disable all grading.
Strangely it seems like using transitions on audio tracks slows the system down a lot!
Another issue, where the audio meters would keep expanding to 8 channels, even though I minimised them, seems to be fixed. But there are still some issues with the delivery page, where settings can kind of get stuck - requiring to restart the Project. Also no audio only export.
This was tested on the new MBP with 16GB RAM.
Keep it coming Blackmagic : )
- No Parking Production -
Adobe CC2014, 3 x MacPro, 3 x MbP, Ethernet File Server w. Areca ThunderRaid 8
Oliver Peters
Re: Resolve 12 Beta 2 improved performance
on Aug 4, 2015 at 11:56:30 pm
[Morten Ranmar] "Strangely it seems like using transitions on audio tracks slows the system down a lot!"
Several issues affect performance in the Edit page. Single versus dual-display layouts. Open mixer panels and audio meters. 8-bit versus 10-bit monitoring. Having an external i/o device enabled. Of all of these, an open mixer panel seems to be the biggest drag.
If you want the best performance in the Edit page, then - switch to 8-bit monitoring. Single-screen layout. Close mixer panel and audio meters. Disable external video output.
- Oliver
Orlando, FL
http://www.oliverpeters.com
Erik Lindahl
on Aug 5, 2015 at 10:43:37 pm
...the worlds best color corrector and editor?
Scott Witthaus
on Aug 10, 2015 at 12:12:21 pm
Great color corrector, but as an editor there is a long way to go. Focus on color, BMD!
Scott Witthaus
Senior Editor/Post Production Supervisor
1708 Inc./Editorial
Professor, VCU Brandcenter
Oliver Peters
on Aug 10, 2015 at 12:23:17 pm
What do you find missing or not working? Just curious. In the testing I've done it seems pretty decent at least as an online editor, other than some beta software issues.
Oliver
Orlando, FL
Tony West
on Aug 10, 2015 at 1:49:59 pm
[Morten Ranmar] "Resolve does offer a single button to disable all grading."
Morten, can't you do this in X by just clicking the top Effects button?
