It's Alive!
COW Forums : Apple Final Cut Pro X Debates
David Mathis
It's Alive!
on Jul 27, 2015 at 8:07:05 am
You heard right, the wait is over. The new version of Resolve is here, in beta form! Going to install Tuesaday, still nothing new on Fusion, hopefully soon.
The magnetic timeline, it's magnetic-o-matic!
Gabe Strong
Re: It's Alive!
on Jul 27, 2015 at 8:17:37 am
Ha, I so beat you to the post....by a little over one minute....
Already playing with it....so far I like!!!!
Gabe Strong
G-Force Productions
http://www.gforcevideo.com
Scott Witthaus
Re: It's Alive!
on Jul 27, 2015 at 11:11:37 am
Does it actually play back material without dropping frames? R11 was such a dud that I have stopped looking at Resolve as an edit solution, only a color corrector when absolutely needed.
Scott Witthaus
Senior Editor/Post Production Supervisor
1708 Inc./Editorial
Professor, VCU Brandcenter
Gabe Strong
Re: It's Alive!
on Jul 27, 2015 at 6:59:35 pm
From what I can tell, it is highly dependent of the GPU, so it really
depends what card you have as far as good real time playback.
I have been searching through the 'DaVinci Configuration guide'
in search of approved cards, and can only find 10 listed 'approved' GPU's.
It also says that 'minimum' GPU RAM for HD is 2 GB, 'approved' is 3 GB
and 'minimum' GPU RAM for UHD/4K is 4 GB and 'approved' is 8 GB.
So in theory if you have a card that meets those specs you are good.....
Gabe Strong
G-Force Productions
Craig Shields
Re: It's Alive!
on Jul 27, 2015 at 1:26:14 pm
I know it's beta but it still doesn't seem too responsive on a new Macbook Pro.
Steve Connor
Re: It's Alive!
on Jul 27, 2015 at 2:34:18 pm
On my systems it's much faster, but still not fast enough. However I imagine that it will work well on a higher spec system
Andrew Kimery
Re: It's Alive!
on Jul 27, 2015 at 4:08:07 pm
Anyone tried syncing multiple cameras by waveform? I asked about it at NAB and a BM rep said that function was still pretty raw so they weren't demoing it on the show floor. Hopefully it's made a lot of headway since then.
Morten Ranmar
Re: It's Alive!
on Jul 27, 2015 at 6:52:25 pm
I'm running a 2.5 Ghz i7 MBP with 16Gb RAM, and responsiveness seems OK.
If I apply heavy grading and go back to editing, it does drop frames, but that could be expected.
So far like what I see...
- No Parking Production -
Adobe CC2014, 3 x MacPro, 3 x MbP, Ethernet File Server w. Areca ThunderRaid 8
Craig Shields
Re: It's Alive!
on Jul 27, 2015 at 7:36:06 pm
Really, your fans don't crank up? What about when you scrub the timeline? Also, do you have any issue with audio when importing different codecs like mxf?
Morten Ranmar
Re: It's Alive!
on Jul 27, 2015 at 8:22:01 pm
After layering a couple of more effects and doing some speed changes I get some fan activity.
Hopefully the main release will be a little more optimised - but this is a lot better than v11.
Craig Shields
Re: It's Alive!
on Jul 27, 2015 at 8:50:24 pm
Guess I'll have to wait another year for 13. It's a pity because its such a beautiful UI. But I need my scrub and JKL to be fast and responsive.
Bret Williams
Re: It's Alive!
on Jul 28, 2015 at 12:46:17 am
Lite only has one user (admin)?
Oliver Peters
Re: It's Alive!
on Jul 28, 2015 at 1:21:41 am
Playback is still very choppy to the viewer in this initial beta. That's on the edit page without any grades. No better than R11 yet. FPS indicator appears that it is up to speed without dropping frames. This would appear that the refresh rate to the viewer isn't right.
- Oliver
Orlando, FL
http://www.oliverpeters.com
Bret Williams
Re: It's Alive!
on Jul 28, 2015 at 2:26:25 am
My playback seemed fine. Not much testing though. But in R11 the audio and playback would stutter if you moved the freakin mouse during playback. Not true of R12. I can adjust audio on the mixer too, which in R11 just basically was completely a no go.
Ricardo Marty
Re: It's Alive!
on Jul 28, 2015 at 2:19:50 am
heres more info on yhe new release
https://forums.creativecow.net/readpost/277/33413
David Mathis
Re: It's Alive!
on Jul 28, 2015 at 5:08:15 pm
Not sure about Lite but in Studio you have to go to preferences to add more users.
A bit off topic but I think an important question. Is anyone using the builder in the new version of Sapphire?
Steve Connor
Re: It's Alive!
on Jul 28, 2015 at 2:29:12 pm
[David Mathis] "You heard right, the wait is over. The new version of Resolve is here, in beta form! Going to install Tuesaday, still nothing new on Fusion, hopefully soon.
Sadly David, I think you're going to be disappointed by Resolve 12, its a big improvement but I don't think its ready to replace any mainstream NLE's .....yet.
David Mathis
Re: It's Alive!
on Jul 28, 2015 at 4:00:24 pm
[Steve Connor] "[David Mathis] "You heard right, the wait is over. The new version of Resolve is here, in beta form! Going to install Tuesaday, still nothing new on Fusion, hopefully soon.
Sadly David, I think you're going to be disappointed by Resolve 12, its a big improvement but I don't think its ready to replace any mainstream NLE's .....yet."
I agree, the edit page performance in the previous version reminds me of this:
