Crop Feather?/ Trim Feather
COW Forums : Apple Final Cut Pro X Debates
brian mclean
on Jul 1, 2011 at 6:42:06 pm
FCP X is there a crop or trimming feather edges like fcp 7?
if so where? I can't find it!
It must be missing
Simon Ubsdell
Re: Crop Feather?/ Trim Feather
on Jul 1, 2011 at 6:49:11 pm
You have to use the Mask effect which has a feather control. You can't do this directly to a trim - note that what we used to call a crop is now a trim. A crop is a crop plus a resize in order to help you make your footage fit the frame.
Simon Ubsdell
Director/Editor/Writer
http://www.tokyo-uk.com
brian mclean
on Jul 1, 2011 at 8:46:31 pm
I miss just doing a crop and simple feather edges...:(
Simon Ubsdell
on Jul 1, 2011 at 8:48:12 pm
Who knows, maybe in a year from now you might get it back. Don't despair just yet!
Simon Ubsdell
Sam Edsall
on Dec 2, 2011 at 7:08:26 pm
I have the same problem and this is huge. You can apply a mask and feather a clip, but if you then crop it to allow for a soft blend between the connected clip and the clip on the main storyline, you LOSE THE FEATHER. This really sucks. The feather does not change to the new cropped clip but IT SHOULD.
To fix this problem Apple needs to add feather back to the crop tool like it did on every other version of FCP known to mankind.
Simon Ubsdell
on Dec 2, 2011 at 7:55:13 pm
You could always try using one of the many free third party effects that offer this functionality, like this one that I made a while back:
3009_tkyadjustableframev4.zip
There are lots of extra control options there which should answer your needs.
Simon Ubsdell
Sam Edsall
on Dec 2, 2011 at 8:50:00 pm
Thanks.
bud kuenzli
on Feb 6, 2013 at 9:08:01 pm
that link does not work any longer and I'm also looking for a crop and feather effect that will allow me to ajust the left/right/up/down crop while maintaining a feathered edge...
Simon Ubsdell
on Feb 6, 2013 at 9:44:38 pm
[bud kuenzli] "that link does not work any longer and I'm also looking for a crop and feather effect that will allow me to ajust the left/right/up/down crop while maintaining a feathered edge..."
You can use the Crop and Feather effect now in FCP X, or you could try out this effect which has onscreen controls for adjusting the left/right and top/bottom crop, offset controls and the ability to apply horizontal and vertical feather independently of each other:
5395_tkyadjustablecropinstaller.app.zip
Double click the archive to unzip it and then double click the installer to install.
Hope that's useful.
Simon Ubsdell
Hector Ceron
on Oct 30, 2012 at 8:05:41 pm
Es posible hacerlo con un filtro llamado "crop & feather" de la carpeta "distortion" del panel "effects", que viene por default en FCPX.
Can be done with the filter "crop & feather" on folder "distortion" in panel "effects", which comes by default in FCPX.
Stephen Fullerton
on Jul 13, 2015 at 5:10:04 pm
Hey, sorry for digging up an old post, just wondering if a good solution ever came up for this. I really miss the way feathering used to be, finding it hard now. Any suggestions I find in forums or videos say use mask but my 10.2.1 doesn't have that mask. Is it named something new now?
Simon Ubsdell
on Jul 13, 2015 at 5:58:15 pm
Do check out my TKY Super Crop which can you find among my free effects here: http://tokyo-uk.com/fcpxeffects/freedownloads.html
It's got some nice features, I think.
Simon Ubsdell
tokyo-uk.com
Stephen Fullerton
on Jul 17, 2015 at 12:48:29 pm
Thank you so much Simon, you just saved me a ton of work :) I spent lots of time reading trying to get this issue sorted, heck I even considered bringing clip into old FCP.
Really appreciated, bookmarked your webpage to go back and see what else you have when the time allows it.
Thanks again.
Simon Ubsdell
on Jul 17, 2015 at 1:57:21 pm
Hi Stephen
Glad to know if helped :)
Simon Ubsdell
tokyo-uk.com
