Importing .MXF file problem
COW Forums : Apple Final Cut Pro X Debates
Gareth Chan
on Jun 18, 2015 at 7:03:37 pm
I updated my final cut to 10.2, updated my OSX with Pro format support, downloaded the Sony plugin for FCPX but how come in final cut when I try to import my .MXF file shot on Sony F7S it only has sound and no video??? I can't edit my .mxf files please help!,
Jeremy Garchow
Re: Importing .MXF file problem
on Jun 19, 2015 at 2:50:38 pm
As far as I know, fs7 media should be xavc which fcpx handles just fine.
How are you importing the media? Drag and drop or import window?
John Rofrano
on Jun 20, 2015 at 1:59:08 pm
You said that you downloaded a Sony plug-in but FCP X can now import MXF natively. Could it be that the Sony plug-in is actually preventing FCP X from using it's native capabilities?
I recently got a warning when FX Factory applied an update that I had an old XDCAM plug-in that was no longer needed and it recommended that I delete it so I did. Perhaps you are in a similar situation with FCP X recently adding MXF support.
Try removing the Sony plug-in.
~jr
http://www.johnrofrano.com
http://www.vasst.com
Jeremy Garchow
on Jun 20, 2015 at 3:14:50 pm
I don't think this matters. The Apple plugin seems to be the exact same Sony plugin. Both of these rewrap the footage to .mov (a waste in my opinion)
I drag and drop XAVC material to use the native MXF and bypass the import window.
