FCPX - Multi track quicktime export
COW Forums : Apple Final Cut Pro X Debates
Chris Lee
on Apr 9, 2015 at 8:18:18 pm
I'm trying to export a multi-track QT movie, so that my clients on the other end will be able to open the mov with all tracks 1-6 laid out. I've tried assigning roles, and exporting using the multi-track quicktime option, but it always ends up collapsed into one single track.
Any help?
Specs. FCPX 10.1.4
Charlie Austin
Re: FCPX - Multi track quicktime export
on Apr 9, 2015 at 8:59:53 pm
[Chris Lee] " but it always ends up collapsed into one single track."
You should see this in the Export window, where you assign roles to separate channels..
~ My FCPX Babbling blog ~
~"It is a poor craftsman who blames his tools."~
~"The function you just attempted is not yet implemented"~
Fabrizio D'Agnano
on Apr 9, 2015 at 11:01:40 pm
Maybe you already know, but if you import a multi track file after export and place it on a timeline to check if everything's OK, you'll see only one audio track. To reveal all the tracks in the timeline you need to check "expand audio components".
Fabrizio D'Agnano
Rome, Italy
early 2008 MacPro, BM Intensity Pro, early 2008 iMac, 2014 MacBook Pro Retina, Blackmagic UltraStudio Mini Monitor, FCP7, FCPX, OSX 10.9.4
