Apple Nanny
COW Forums : Apple Final Cut Pro X Debates
Oliver Peters
Apple Nanny
on Mar 26, 2015 at 2:10:16 pm
http://appleinsider.com/articles/15/03/26/apple-concept-would-require-users...
Hopefully this never goes past a patent. If they implement this, it will be a good reason to swear off using their products.
Oliver
Orlando, FL
http://www.oliverpeters.com
Jeremy Garchow
Re: Apple Nanny
on Mar 26, 2015 at 3:27:01 pm
[Oliver Peters] "Hopefully this never goes past a patent. If they implement this, it will be a good reason to swear off using their products."
The pictures show a "close" button to these user set reminders. If you don't want them, delete the reminder. Why would you swear off a product because you don't want to follow up on your own reminders?
Mark Suszko
Re: Apple Nanny
on Mar 26, 2015 at 3:27:10 pm
Seems like a very narrow and voluntary application, if you volunteer to be in one of their health studies, you already want to submit this data anyhow. If you're not a participant in the health science kit apps, then this is never an issue.
The potential power of phone networks to enhance public safety is a huge draw. Consider an add-on module to phones, subsidized and voluntary, that has a gas detector, sensitive to a few major toxins. What would a city Emergency Services director not give, to be able to have a network of mobile sniffers scanning his or her city and reporting suspicious peak levels down to the city block level?
There are already less intrusive means to do something like this, done by monitoring anonymized chats and texts for keywords and cross-referencing them to geospacial location data. A system like that can give early warning of an epidemic by measuring bursts of chatter about illnesses, coughs, colds, etc.
Jeremy Garchow
Re: Apple Nanny
on Mar 26, 2015 at 3:46:29 pm
[Mark Suszko] "Seems like a very narrow and voluntary application,"
It seems to be be an add on to the existing Reminders application, but it lets you add a call to action in the form of shortcut to another app or process.
"Remind me to take a picture of grandma when I see her" and the Reminder will have a button to open the camera when you get to grandma's house instead of just a pop up telling you to take a picture.
Chris Northcross
Re: Apple Nanny
on Mar 26, 2015 at 3:54:12 pm
Could you elaborate on why it would be a good reason to swear off using their products Oliver?
Whether you believe that you can or you can't, you're absolutely right.
Oliver Peters
Re: Apple Nanny
on Mar 26, 2015 at 8:01:27 pm
Here's the actual filing:
http://appft.uspto.gov/netacgi/nph-Parser?Sect1=PTO2&Sect2=HITOFF&u=/netaht...
The abstract explains it in a synopsis (emphasis mine):
"Techniques are disclosed for presenting notifications that can receive input data. The techniques include presenting a notification in response to occurrence of an event, wherein the notification is associated with a specified data type and a data source from which data is to be received, receiving input data of the specified data type from the data source, wherein the notification is presented until the input data is received, and storing the input data. The notification can block access to a user interface of at least one application until the input data is received. The data source can be a data entry component of a user interface that receives user input, or can be an application that provides data of the specified data type, and receiving input data can include requesting data of the specified data type from the application, and receiving the input data from the application via inter-process communication."
I don't see anything about voluntary as described in the filing, however, I really don't think Apple will actually apply it in such a heavy-handed way as the patent description explains. So I'm not really that worried about it. If this is indeed applied in a voluntary or "opt in" method, that's fine. No problem. Hopefully Apple is actually that smart. I prefer Apple to continue to make great products instead of deciding they should be social engineers.
I think health was merely used as an example for the purpose of filing the patent, however, I'm of the opinion that storing health data on your phone is a pretty ill-conceived and dangerous idea given the attraction this poses for hackers. Using it to lock you out of your device is a terrible idea.
- Oliver
Orlando, FL
Aindreas Gallagher
Re: Apple Nanny
on Mar 26, 2015 at 8:45:12 pm
there is something to the notion that inside the apple dojo, perfecting user experiences runs a little into perfecting user behaviour. There is a bit of the maestro problem there.
I never personally madly hankered after a bonkers timeline - but apple made a number of full on decisions about what a timeline should be, and how new editors should operate when preparing and executing an edit. I like the fact that they've stuck with it thus far insofar as they aren't completely obsessed with aluminium force touch and terraced batteries, but in terms of an apple nanny, the X timeline is one of the most nanny-ish primary secondary auto linking thing ever made. It's partly why a person might involuntarily spit the editing system out every time they go near it.
Apple deciding to intervene in health to better outcomes is kind of hard to argue with, but I do have a weird vision of them seeing users as shrubs to tend in their walled garden. The very rich and the corporate are really probably not like us?
http://vimeo.com/user1590967/videos http://www.ogallchoir.net promo producer/editor.grading/motion graphics
Oliver Peters
Re: Apple Nanny
on Mar 26, 2015 at 8:54:25 pm
[Aindreas Gallagher] "Apple deciding to intervene in health to better outcomes is kind of hard to argue with, but I do have a weird vision of them seeing users as shrubs to tend in their walled garden. The very rich and the corporate are really probably not like us?"
Congrats! You found the shift key!
So, sitting all day is bad for editors' health. What if Apple decided there was a way to only operate FCP X while standing up? ;-)
Or, if they really cared about our health (and not just control for its own sake) they would make iPhone data functions inoperable while in a moving vehicle. ;-)
- Oliver
Orlando, FL
Aindreas Gallagher
Re: Apple Nanny
on Mar 26, 2015 at 9:07:19 pm
[Oliver Peters] "So, sitting all day is bad for editors' health. What if Apple decided there was a way to only operate FCP X while standing up? ;-)"
In that instance small electrical shocks delivered through the apple watch would be the best thing. then the magnetometer on the iphone could register you staggering to your feet and the mac, the iphone and the apple watch would all play a trumpet medley simultaneously. days of wonder really.
Oliver Peters
Re: Apple Nanny
on Mar 26, 2015 at 9:44:27 pm
[Aindreas Gallagher] "In that instance small electrical shocks delivered through the apple watch"
But only if you ponied up for the $17K Gold Edition. Oh wait, if you afford that you'd be a director or an agency producer!
- Oliver
Orlando, FL
Jeremy Garchow
Re: Apple Nanny
on Mar 29, 2015 at 3:31:08 am
[Oliver Peters] "The notification can block access to a user interface of at least one application until the input data is received. "
I read this as you either have to take the picture, or hit close. I do not understand this as saying you have to take the picture (or enter whatever data) and nothing else. The only thing I see here is a sensational headline on the article.
Oliver Peters
Re: Apple Nanny
on Mar 29, 2015 at 1:17:45 pm
[Jeremy Garchow] " I do not understand this as saying you have to take the picture (or enter whatever data) and nothing else."
Reading the rest of the filing, I get the opposite understanding. Of course it all falls into the realm of *could* not *would*.
Oliver
Orlando, FL
Oliver Peters
Re: Apple Nanny
on Mar 29, 2015 at 4:43:49 pm
PS: It's quite possible that the implementation would be optional on the part of the user. For example, I may choose to lock up the system unless I enter BP data. The filing does imply that you would be locked out of the system or an app unless you enter the data. There doesn't seem to be any provision to bypass it by clicking "close". You are getting this from the image, not from the actual filing information. You could be right or that could be wishful thinking. Unknown right now. Again, as long as the set-up is optional, I'm fine with it.
- Oliver
Orlando, FL
Jeremy Garchow
Re: Apple Nanny
on Mar 29, 2015 at 7:13:58 pm
[Oliver Peters] "The filing does imply that you would be locked out of the system or an app unless you enter the data. "
It says "input data ". Input data could mean, hit the close button (or home button).
There are many apps that do this already. You can't use the app until you sign in to an account, just for an example. This would be the same, except you couldn't use the app until you get a blood pressure reading. My guess is that this would be some sort of health app that is connected to your doctors office, insurance company, or similar. I highly doubt it would lock down your entire phone, as why would any device manufacturer want that? But an app developer may want that, as the user input is required, for whatever reason, to continue to use the app. Without that information, the app may be rather useless.
Oliver Peters
Re: Apple Nanny
on Mar 29, 2015 at 7:18:09 pm
[Jeremy Garchow] "I highly doubt it would lock down your entire phone, as why would any device manufacturer want that? "
Remember we are talking about Apple here ;-) No one understand anything they do.
[Jeremy Garchow] "But an app developer may want that, as the user input is required, for whatever reason, to continue to use the app. Without that information, the app may be rather useless."
Agreed. It does seem to focus on "application" in the description. It could be something you set-up for yourself as a self-monitoring reward system of sorts.
- Oliver
Orlando, FL
Robin S. Kurz
Re: Apple Nanny
on Mar 30, 2015 at 11:06:31 am
[Oliver Peters] "It's quite possible that the implementation would be optional on the part of the user."
I'd say it's a huge stretch to assume anything else... unless of course you simply wanted to. In which case...
Never mind that 99.x% of Apple's patents never even see the light of day as an actual product, nor is a patent file some sort of source for reality even by the same stretch. As if one could even muster up the most obscure scenario where this could pose as some sort of GAIN for the iPhone, let alone Apple. I'd say "far fetched" doesn't even begin to describe it.
- RK
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
