Scientific Yosemite Testing..
COW Forums : Apple Final Cut Pro X Debates
Charlie Austin
on Oct 17, 2014 at 11:03:12 pm
The results of my highly technical scientific tests are in! FCP X 10.1.3 works fine in Yosemite. Snappy even! No problems yet , and I’ve been hammering it for a while. Go for it!
Also, for what it’s worth… FCP 7, Adobe Pr and AE CC, and Soundtrack Pro all good as well. No functionality differences from Mavericks as far as I can tell. Avid MC 8 appears to be OK, though I haven’t done much in it, and Resolve 11 seems OK too, though I had to switch the GPU to use OpenCL rather than CUDA. (2012 iMac) Might just be me though.
So… All good, dive in!. But, if it all blows up… don’t blame me!
~ My FCPX Babbling blog ~
~"It is a poor craftsman who blames his tools."~
~"The function you just attempted is not yet implemented"~
David Mathis
Re: Scientific Yosemite Testing..
on Oct 17, 2014 at 11:44:09 pm
Stupid question time: Does anyone have know whether Shake will run under Yosemite?
camera operator | editor | production assistant
Ronny Courtens
on Oct 18, 2014 at 6:10:41 am
Have tested it. Good old Shake is finally laid to rest in Yosemite.
- Ronny
David Mathis
on Oct 18, 2014 at 4:12:49 pm
Thanks for the update. Ran into a brick wall trying to install Resolve and the BMD camera utility. Says that OS X 10.6 or later is required. Ugh!
Don Scioli
on Oct 18, 2014 at 4:12:55 pm
How about using multiple monitors...mine have not worked since 10.9.2, which I stayed with. I'm using 3 HD monitors, 10801 not 4k on a 6 core Mac Pro 2014.
Fabrizio D'Agnano
on Oct 20, 2014 at 8:41:32 pm
Did you install Yosemite on top of Mavericks or went through a clean install?
By the way, I never succeeded installing Soundtrack Pro on Mavericks, did you install it from the disc or in some other way?
Thank you!
Fabrizio D'Agnano
Rome, Italy
early 2008 MacPro, BM Intensity Pro, early 2008 iMac, 2014 MacBook Pro Retina, Blackmagic UltraStudio Mini Monitor, FCP7, FCPX, OSX 10.9.4
Charlie Austin
on Oct 20, 2014 at 8:54:04 pm
[Fabrizio D'Agnano] "By the way, I never succeeded installing Soundtrack Pro on Mavericks, did you install it from the disc or in some other way?"
From Disc Images... Gotta be FCS 3 though, earlier installers won't work...
