FCP X undo bug?
COW Forums : Apple Final Cut Pro X Debates
Xavier Paredes
FCP X undo bug?
on Oct 17, 2014 at 4:12:58 pm
Second time this happens to me: I create a temporary project (just to add all my clips total run time) then undo a few times to delete it and when I quit and reopen FCP, the project I had previously deleted is there but with the yellow triangle and exclamation mark inside it.
When I try to delete it, FCP X crashes forcing me to go to the beach by giving me that colorful ball!
I know I can open backed up copies of the library but has anyone else experienced this? Is there another way to delete that problem project?
Xavier
Robin S. Kurz
Re: FCP X undo bug?
on Oct 17, 2014 at 4:34:01 pm
Simply right-click on the library in the Finder, show its package contents and manually move the respective event/project to the trash.
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
Xavier Paredes
Re: FCP X undo bug?
on Oct 17, 2014 at 7:27:08 pm
Thanks! I'll try that if it happens again. While I was waiting for someone to respond what I did was create a new Library and I then dragged everything except the offending item to it. Worked. I'll keep my fingers crossed.
Xavier
Robin S. Kurz
Re: FCP X undo bug?
on Oct 18, 2014 at 6:18:42 am
[Xavier Paredes] "While I was waiting for someone to respond what I did was create a new Library and I then dragged everything except the offending item to it."
That of course being the far more elegant and safer alternative, yes. Good thinking. ;)
