How to deal with original video frame from current video frame?
COW Forums : Apple Final Cut Pro X Debates
Mansur Oscar
on Aug 17, 2014 at 11:43:42 pm
The video is originally 25 frames, but I captured or recorded as 60 frames (current) on my computer using QuickTimeX exactly 60 frames (not 59 once)
it's perfectly recorded, but maybe it's a huge file or it may not be playable on some devices. I have tried FCPX to put into 60, 30 and 25 frames projects, nor of them was same as recorded quality (or movements), only project 60 frame was the same exactly (exported 60p only).
inspector keep says current frame is 60, and originally is 25 frame.
So, 25p was bad, and 30p was better, 60p is exactly same. and the video is originally 25 frames.
What do you do to fix this problem?
Shane Ross
Re: How to deal with original video frame from current video frame?
on Aug 18, 2014 at 7:34:20 am
[Mansur Oscar] "The video is originally 25 frames,"
Where did said video originate? Camera? Web?
[Mansur Oscar] "but I captured or recorded as 60 frames (current) on my computer using QuickTimeX exactly 60 frames (not 59 once)"
60fps, straight up? not 59.94? Why did you do this? Why not at 25fps?
[Mansur Oscar] "So, 25p was bad, and 30p was better, 60p is exactly same. and the video is originally 25 frames.
What do you do to fix this problem?"
Record the video at 25fps, not 60fps
Shane
Little Frog Post
Mansur Oscar
on Aug 18, 2014 at 11:48:08 am
recorded live from web, internet tv using quicktimeX, and I didn't know how to select to 25 rather than 60 from quicktime, & the more important... I can't record it anymore, it's gone on web.
you said "where it says originally frames", of course I used videospec and iMediaHUD to know the MOV captured, all of them said the current frame is 60 but originally is 25 frames.
So again, The video is a PAL square pixel, 768x576/25p, and I recorded as 768x576/60p (used selection quicktimeX).
from current frames > to > original frames = how? (without reduce quality)
Shane Ross
on Aug 18, 2014 at 4:21:02 pm
Possibly Compressor to convert the footage and the frame rate. With 60fps to work from, it should get 25fps fine...but will it get the EXACT 25fps of the original video? Not sure. Test test test.
Next time, use an app that can capture (or export) at the frame rate needed. ScreenFlow does great with this.
Shane
Little Frog Post
Mansur Oscar
on Aug 18, 2014 at 9:11:34 pm
Well, I tried with compressor too, it isn't same as 60 frames (movements),
but Thank you Shane Ross for the Screenflow app, i will try this next time.
Walter Soyka
on Aug 18, 2014 at 7:32:14 pm
If Shane's Compressor suggestion doesn't work:
Do you have a PC? If so, I'd try AviSynth with a duplication detection filter [link].
Failing that, if the 25-in-60 frame repetition cadence is regular (it should be 2-2-3-2-3 if my math is correct) then you can remove it in After Effects with time remapping and an expression. Drop by the Ae forum [link] and I'll help you out there.
Walter Soyka
Mansur Oscar
on Aug 18, 2014 at 9:22:03 pm
I Thank you Walter Sokya for helping.
The compressor doesn't do the job, nor FCPX too, and as I said above, 25 worse, 30 better, 60 is same.
the duplication deletion maybe is a great idea!, but are you sure it's same as 60? and would this delete the correct one only? I don't like to loose any frames originally!
and yes it's 25 frames in 60 frames video.
I'm right now on Mac, I may not able to come to windows soon. perhaps next month? :)
Do you have any other ideas? (especially on Mac)
Thanks dear! :)
Walter Soyka
on Aug 18, 2014 at 9:43:24 pm
I'm not sure. You have to step through the footage one frame at a time and see if the repeated frames follows this exact pattern:
Frame A 2x
Frame B 2x
Frame C 3x
Frame D 2x
Frame E 3x
If it does, and if you have After Effects, I can walk you through non-destructively outputting a clean 25fps version.
If not, then AviSynth (PC only) might be your best bet. I used it once some time ago for something similar.
(By the way, you probably intended this for the FCPX Techniques forum [link]. This is the debate forum and it's not generally about specific how-to questions.)
Walter Soyka
Mansur Oscar
on Aug 20, 2014 at 9:10:33 pm
All right!
I will open a new thread when I'm ready.
Thanks again! :)
