Titles - font tracking keyframes
COW Forums : Apple Final Cut Pro X Debates
Oliver Peters
on Jun 25, 2014 at 9:40:37 pm
Is there a way to enable keyframes in the Title generators' tracking slider? This doesn't appear to be possible, even though it can be done in Motion. Sending the effect over from Motion comes across still without the ability to add keyframes once in FCP X. I want the letters to be able to grow apart over the length of the clip, so a start and end keyframe are needed. The template tracking title effects don't allow control over timing.
- Oliver
Orlando, FL
http://www.oliverpeters.com
Andy Neil
Re: Titles - font tracking keyframes
on Jun 25, 2014 at 10:38:26 pm
Could you try a behavior in the Motion project? There's a parameter behavior called Ramp that should accomplish what you're trying to do. Just publish all the parameters and you should be good to go.
Andy
https://plus.google.com/u/0/107277729326633563425/videos
Oliver Peters
on Jun 26, 2014 at 12:04:46 am
That works. Thanks.
- Oliver
Orlando, FL
