Mavericks update might cause headaches
COW Forums : Apple Final Cut Pro X Debates
Andre van Berlo
on May 22, 2014 at 7:10:05 am
http://www.macissues.com/2014/05/21/10-9-3-causing-headaches-for-mac-pro-us...
"Some Mac Pro users have noticed that after updating their systems to OS X 10.9.3, their systems are showing significant graphical artifacts that can impact their work in video editing software packages, especially when exporting video files.
For affected systems, in some cases pink and green lines may be embedded in exported video files, and in other cases the exporting process may stall out and not complete properly. Either way, this issue appears to be a compatibility problem with the drivers for the AMD video chipset in the new Mac Pro, and various popular video editing software packages.
This issue is being looked into by Apple engineers, so a fix may be supplied soon in a supplemental update to OS X 10.9.3. Meanwhile, there are several things you can do to work around this problem."
Nick Toth
Re: Mavericks update might cause headaches
on May 22, 2014 at 11:53:58 am
Sounds like "click bait" to me. Is anyone here seeing this?
anickt
Oliver Peters
on May 22, 2014 at 12:33:08 pm
There's a thread on this that I started in the Premiere Pro forum. Apparently 10.9.3 causes render issues with Adobe apps and Resolve when GPU accelerated rendering is used. It appears to be tied to the D500 and D700 GPUs on the new Mac Pros.
http://forums.creativecow.net/thread/3/954153
Oliver
Orlando, FL
http://www.oliverpeters.com
Scott Witthaus
on May 22, 2014 at 1:07:49 pm
Another lesson in patience before updating....
Scott Witthaus
Senior Editor/Post Production Supervisor
1708 Inc./Editorial
Professor, VCU Brandcenter
Oliver Peters
on May 22, 2014 at 1:40:21 pm
[Scott Witthaus] "Another lesson in patience before updating...."
While true, this affects the new Mac Pros. These are just now shipping, so hard to say which OS comes installed. You might not have a choice.
- Oliver
Orlando, FL
Mitch Ives
on May 22, 2014 at 4:38:53 pm
[Oliver Peters] "While true, this affects the new Mac Pros. These are just now shipping, so hard to say which OS comes installed. You might not have a choice."
I can't verify this, but someone has also posted on Apple forums that this is affecting his older MacPro (2008). FWIW, I have a 2008 and a new MacPro, but I haven't seen it in FCP X. Can't speak to Resolve or Premiere...
Mitch Ives
Insight Productions Corp.
"Criticism may not be agreeable, but it is necessary. It fulfills the same function as pain in the human body. It calls attention to an unhealthy state of things." - Winston Churchill
Nick Toth
on May 22, 2014 at 3:26:56 pm
Ah Ha! Thanks Oliver
anickt
Scott Witthaus
on May 22, 2014 at 3:46:58 pm
"Some Mac Pro users have noticed that after updating their systems to OS X 10.9.3, their systems are showing significant graphical artifacts that can impact their work in video editing software packages, especially when exporting video files."
This is what I was referring to. This line suggest the users DID have a choice!
Scott Witthaus
1708 Inc./Editorial
Oliver Peters
on May 22, 2014 at 5:14:47 pm
[Scott Witthaus] "This is what I was referring to. This line suggest the users DID have a choice!"
Correct. But, if you buy a new Mac Pro today and get it in 2 weeks, what OS will be installed now that 10.9.3 is out? And will this issue be solved by then? That was my point.
- Oliver
Orlando, FL
Warren Eig
on May 22, 2014 at 5:28:09 pm
Also note, Nvidia released drivers and Cuda for 10.9.3 yesterday.
Warren Eig
O 310-470-0905
email: warren@babyboompictures.com
website: http://www.BabyBoomPictures.com
REEL: http://www.babyboompictures.com/BabyBoomPictures/Reels.html
For Camera Accessories - Monitors and Batteries
website: http://www.EigRig.com
Scott Witthaus
on May 23, 2014 at 11:59:16 am
[Oliver Peters] "But, if you buy a new Mac Pro today and get it in 2 weeks, what OS will be installed now that 10.9.3 is out? And will this issue be solved by then?"
That's a buyer awareness issue. What you do then is not use the new box until the issue is fixed. Tough to do, but solves the problem.
Scott Witthaus
1708 Inc./Editorial
