Screen Recorder
COW Forums : Apple Final Cut Pro X Debates
David Mathis
Screen Recorder
on Mar 20, 2014 at 8:52:09 pm
Looking at doing a few how to videos but looking for a high quality screen recording software that will be less than $50 USD, if at all possible. Thanks!
Bill Davis
Re: Screen Recorder
on Mar 20, 2014 at 8:59:11 pm
Quicktime Pro does it for free with GREAT results.
If you want to spend money on a more full-featured solution, Telestream Screencast is widely used.
Know someone who teaches video editing in elementary school, high school or college? Tell them to check out http://www.StartEditingNow.com - video editing curriculum complete with licensed practice content.
David Mathis
Re: Screen Recorder
on Mar 20, 2014 at 9:11:18 pm
Does it record sound as well? I plan to do some minor editing (as needed) in FCP X, assume this should not be an issue. Thanks for the fast response!
Al LeVine
Re: Screen Recorder
on Mar 20, 2014 at 9:24:14 pm
If you want to record in-computer audio, the cheat is to get an AUX cable and connect it to your headphone port then loop it to your microphone port -- given you have these ports.
If you have one of those Macs that ships with a single aux plug, you can try Soundflower.
Jeremy Garchow
Re: Screen Recorder
on Mar 20, 2014 at 10:04:34 pm
If you want to double your budget, Screenflow is well worth it.
http://www.telestream.net/screenflow/overview.htm
You can edit, title, even key green screen in it if you want. It also records audio.
Jeremy
Dave Gage
Re: Screen Recorder
on Mar 20, 2014 at 10:35:03 pm
[Jeremy Garchow] "If you want to double your budget, Screenflow is well worth it.
You can edit, title, even key green screen in it if you want. It also records audio."
What he said. ScreenFlow and Disk Warrior are the two best $100 purchases I've made in the last few years. ScreenFlow support is excellent too.
Dave
Andre van Berlo
Re: Screen Recorder
on Mar 21, 2014 at 1:13:49 pm
For recording computer audio i believe you can use soundflower should you want to go with quicktime solution.
I personally use screencast
Mitch Ives
Re: Screen Recorder
on Mar 21, 2014 at 3:25:57 am
Screenflow or Camtasia. I'm doing a bunch with Camtasia right now... great quality...
Mitch Ives
Insight Productions Corp.
"Criticism may not be agreeable, but it is necessary. It fulfills the same function as pain in the human body. It calls attention to an unhealthy state of things." - Winston Churchill
Phil Hoppes
Re: Screen Recorder
on Mar 21, 2014 at 12:54:53 pm
I use Screenflow on the Mac and Camtasia on my PC. If you do or plan to do a lot of screen captures these programs are quite worth while. If it is one shot or a few shot kind of deal just use what is built into OSX.
Dave Brandt
Re: Screen Recorder
on Mar 21, 2014 at 1:41:43 pm
We use iShowU HD. Does sound, mouse cursor etc and all for $29.99
http://www.BrandtStudios.ie
Macbook Pro Retina 15" i7 2.7 16GB Early 2013
PC i7 32GB Self Build
FCPX LogicX Adobe CC Vegas 12 Nuendo 4
