Slightly OT: How to make a video look like it was shot with a camera that had a broken lens
COW Forums : Apple Final Cut Pro X Debates
David Mathis
on Mar 16, 2014 at 9:45:40 pm
Any ideas on how to create such an effect? Would like to do this in FCP X if at all possible. Thank you!
Andy Neil
Re: Slightly OT: How to make a video look like it was shot with a camera that had a broken lens
on Mar 16, 2014 at 10:11:04 pm
[David Mathis] "Would like to do this in FCP X if at all possible."
I guess it depends on the actual look you're going for. You could duplicate the clip a couple times above the original clip, resize, mask off portions, and put a slight blur on the different "pieces". It would be much easier to build it as an effect inside Motion that you can just add to a clip. A lot more flexibility and ease of use.
Andy
https://plus.google.com/u/0/107277729326633563425/videos
Erik Lindahl
on Mar 16, 2014 at 11:39:52 pm
As mentioned above I'd do something similar and base it all around something like a picture like this:
http://www.ormsconnect.co.za/2013/07/video-golf-ball-strikes-camera-at-brit...
Or this:
http://www.myfrienddebbie.com/article_master.php?id=9930548
I'd defiantly do the comp in After Effects or Motion. It would be a headache creating it in FCP given it might be achievable.
The back-plate would have to be treated a lot with blur, chromatic abboration, sclices with various scaling / focus. Not to forget you'd like to simulate the cracked glass in front of this picture, preferable it should also be affected by the picture I tends of light. You might also want to play around with various oddities of light-leaks.
