FCPX stuck in Restore window layout on startup
COW Forums : Apple Final Cut Pro X Debates
Sascha Engel
on Feb 25, 2014 at 3:15:12 pm
Dear X People,
I so pray one of you can help me.
First time I encounter such a bad problem on FCPX and of course it happens on a tight deadline:
I used some clip of the Transcoded High Quality Folder of my FCPX Event in After Effects (imported a clip into AE directly from the EVENT Folder), but I did not change it.
After I realised, that in FCPX this clip went red, saying "Modified Clip", I deleted the AfterEffects Project, that contained that clip and did relinked the Red "Modified Clip" in FCPX. After pressing ok, FCPX froze. I forced quit the app and when I tried to restart, it freezes on the start up window saying "Restore Window Layout".
When I move the Event in question to my archive, the App opens again.
How can I repair my event? I have a deadline on this project in 1 day. I have a back up file in the event (I am on 10.0.8). How can I exchange the actual Event File with the back up?
Maybe that helps?
Any thought are much appreciated!
Greetings,
Sascha Engel
TIME BANDITZ Productions
http://www.youtube.com/taikang
Jari Innanen
Re: FCPX stuck in Restore window layout on startup
on Feb 25, 2014 at 3:54:25 pm
You might try:
http://support.apple.com/kb/TS4169?viewlocale=en_US&locale=en_US
Sascha Engel
on Feb 25, 2014 at 3:55:38 pm
Pfffff, solved it. After deleting the Preference Plists and several weird additional plists that were created, all is ok again.
It made me learn a major lesson: Not only not to modify files within the Event and Project folder, but not even importing (without alternating) any of the FCPX media files into other Apps.
Sascha Engel
Jeremy Garchow
on Feb 25, 2014 at 4:12:09 pm
You need to turn of XMP metadata in Adobe products. This will allow you to use the files in Adobe and FCPX.
Qt Edit from Digital Rebellion will remove XMP data.
Jeremy
Sascha Engel
on Feb 25, 2014 at 4:16:43 pm
Thanx Jeremy and JAri, where do I switch that Metadata off?
Sascha Engel
Jeremy Garchow
on Feb 25, 2014 at 4:32:32 pm
It's in the preferences of both Pr and Ae.
It's called something like "Write XMP ID to files on import" in the "Media" section of prefs. This pref is off by default in CC versions, but on in earlier versions (CS6 and below).
Jeremy
Sascha Engel
on Feb 25, 2014 at 4:56:59 pm
Cannot find it nowhere in Preferences in CS6 AE.
Sascha Engel
Jari Innanen
on Feb 25, 2014 at 5:13:43 pm
AE Prefs -> Media and Disk Cache -> XMP Metadata
Jeremy Garchow
on Feb 25, 2014 at 5:18:06 pm
[Sascha Engel] "Cannot find it nowhere in Preferences in CS6 AE."
See this picture and look towards the bottom:
Jeremy
Sascha Engel
on Feb 25, 2014 at 5:23:51 pm
Muchos Gracias!
Jeremy Garchow
on Feb 25, 2014 at 5:25:36 pm
de nada
Jeremy Garchow
on Mar 3, 2014 at 8:01:44 pm
I wanted to post an update to this.
Sometimes, I think waveform and thumbnails, somehow, get a little corrupt-ish.
If your media and library is on an external drive, it might be best to unmount that drive and then open fcpx, which should open without the restore window hang.
Then once fcpx is open, mount the drive and open the library from within fcpx, and then everything will open.
It's a bit of a workaround, but it does seem to work without having to trash prefs.
Jeremy
Jari Innanen
on Feb 25, 2014 at 4:15:51 pm
If you use CS6 with FCP X, make sure you have the MXP ID write disabled in Media prefs.
