Capture SDI over firewire
COW Forums : Apple Final Cut Pro X Debates
Rich Hawksworth
on Feb 24, 2014 at 8:00:19 pm
I have a library of DVCPRO 50 tapes and a Panasonic AJ-SD93P deck. I've traditionally captured through an IO HD—SDI out of the deck. I've discovered that the IO HD is not supported under FCPX. I don't have to access these tapes very often (like this is the first time in several years) so I'm loath to invest a lot in a "new" capture solution. Any suggestions for an economical ingest setup?
Shane Ross
Re: Capture SDI over firewire
on Feb 24, 2014 at 8:24:53 pm
Does the deck have Firewire connectivity? DVCPRO 50 traditionally does.
The IO devices are now only "O" with FCX...they only work to output to a monitor. The only way to capture directly into FCX is via firewire.
You can, however, capture using the IO makers software. AJA does make a capture utility called AJA VTR EXCHANGE. You can capture with that, and you IO...and then import that into FCX.
Shane
Little Frog Post
Rich Hawksworth
on Feb 24, 2014 at 8:27:10 pm
Unfortunately the FW port on the deck fried a long time ago. $1500 to replace the FW card wasn't worth it while the IO HD was working. I'll try the utility you suggested--thanks!
