modified file problem in multicam edit
COW Forums : Apple Final Cut Pro X Debates
tamir. azoulay
on Jan 14, 2014 at 11:41:45 pm
Hello everybody.
In my first multi cam project in Fcx I'm having serious problems.
first, as i here in the tutorials i change all the files to proxy mood and start to edit multi cam ( it was vary fun)
afterwards i'm switch back to original or optimized media - and i Surprised to find that all the media that was edit in multicam is modified files..
i tried to relink the file from the event but no Success
someone can help please..
Tamir
Jeremy Garchow
Re: modified file problem in multicam edit
on Jan 15, 2014 at 5:11:35 am
If you double click the multicam edit, select the "modified" file, and hot command-shift-r to reveal in Finder, is the media on your hard drive OK?
Jeremy
tamir. azoulay
on Jan 15, 2014 at 9:29:19 am
In the finder everything also show as modified..
Jeremy Garchow
on Jan 15, 2014 at 1:14:25 pm
What is the source of the media (what camera was used)? Is it optimized media, or is it original media?
If it's optimized (in a "High Quality" folder). Trash all the media out of the high quality folder and regenerate the optimized media.
If it's Original media, trash it and reimport the media.
tamir. azoulay
on Jan 15, 2014 at 10:51:49 pm
After i Delete i don't have any option to transcode - see the photo
The camera is canon c100
Jeremy Garchow
on Jan 15, 2014 at 10:53:06 pm
C100 shoots what kind of media? AVCHD?
tamir. azoulay
on Jan 15, 2014 at 10:55:33 pm
yap. AVCHD!
Jeremy Garchow
on Jan 15, 2014 at 10:57:11 pm
Please show me where you deleted the media from.
Jeremy
tamir. azoulay
on Jan 15, 2014 at 11:05:42 pm
i Delete the optimize and the original
Jeremy Garchow
on Jan 15, 2014 at 11:07:59 pm
You should only delete the optimized if there's optimized.
If you have deleted the original as well, you should reimport the material.
Jeremy
