Select Photos without Selecting Transitions
COW Forums : Apple Final Cut Pro X Debates
David Townsend
on Nov 26, 2013 at 6:49:10 pm
In FCPX, I have a still photo slideshow setup with dissolve transitions applied. I need to select all the photos to change the duration, and I cannot figure out how to select all of the still photos WITHOUT selecting the transitions. iMovie has the option in the EDIT menu, but can't find anything in FCPX. Please help!
Matt Galuszewski
Re: Select Photos without Selecting Transitions
on Nov 26, 2013 at 7:37:39 pm
Show the Timeline Index, SHIFT + COMMAND + 2
Click on the word VIDEO at the bottom of this window
Select all the clips, COMMAND + A
David Townsend
on Nov 26, 2013 at 8:52:25 pm
That's it! Thanks so much, couldn't find this answer anywhere else. Also, Is there a way to select just transitions?
Eric Santiago
on Nov 26, 2013 at 7:38:16 pm
Try Timeline Index then filter Video.
Sucks if you have videos as well as photos.
You can shift/command select what ever you wish.
