@John Heagy
COW Forums : Apple Final Cut Pro X Debates
Bob Zelin
@John Heagy
on Oct 24, 2013 at 9:54:00 pm
Hi John -
sorry for repeating this, but I wanted to make sure that you saw this post. Would you be so kind as to tell us EXACTLY WHAT TERMINAL COMMANDS you typed into OS X 10.9 to enable NFS ?
Thank you very much -
Bob Zelin
Bob Zelin
Rescue 1, Inc.
maxavid@cfl.rr.com
John Heagy
Re: @John Heagy
on Oct 24, 2013 at 10:12:30 pm
I not using a Mac to export NFS... below is how I am mounting NFS in 10.9. This is not a persistent mount.
mkdir /Volumes/ingest
mount -o resvport,nolocks,locallocks,intr,soft,proto=tcp -t nfs 10.xxx.xx.xxx:/zpool01/ingest /Volumes/ingest
Bob Zelin
Re: @John Heagy
on Oct 25, 2013 at 12:12:45 pm
thank you John, will try this soon, and report back.
Bob Zelin
Bob Zelin
Rescue 1, Inc.
maxavid@cfl.rr.com
Steve Modica
Re: @John Heagy
on Dec 19, 2013 at 10:08:25 pm
Bob, for persistent Mac NFS mounts, edit /etc/nfs.conf. You can put in nfs options there (like locallocks)
The example mount command above has both "nolocks" and "locallocks" which I think are mutually exclusive.
Steve Modica
CTO, Small Tree Communications
Steve Modica
Re: @John Heagy
on Dec 19, 2013 at 10:11:24 pm
Hi Bob
You want to put this into your /etc/nfs.conf file:
spongebob:~ modica$ cat /etc/nfs.conf
# nfs.conf: the NFS configuration file
nfs.client.mount.options = locallocks
This will automatically put in the NFS options you want on the client.
If you use local locks, the server doesn't need to be running lockd.
Steve
Steve Modica
