impossible to edit with XDCAM EX HD
COW Forums : Apple Final Cut Pro X Debates
Gordian Fritz
on Jun 25, 2011 at 8:35:56 pm
i try to find out how i can edit my XDCAM EX HD stuff with FCP X. Because every time i was stopped by dropframes. Even if i choose "better performance" at the playback preferences.
Why there a drop frames? I edit on a macbookpro duo core 2,66 with 8 GB RAM
the same editing is without any problems on my fcp 7! What is the problem?
Matthew Glasser
Re: impossible to edit with XDCAM EX HD
on Jun 25, 2011 at 9:20:24 pm
Are you trying to edit the native files or have you converted them to Quicktime files? At this point in time, you can't edit the native EX files in X. You need to rewrap them.
Matthew Glasser
CEO / Executive Producer, InteReality Media LLC
Executive Producer, Healthcare Heroes
http://www.InteRealityMedia.com
http://www.HealthcareHeroes.com
Gordian Fritz
on Jun 26, 2011 at 11:06:25 am
I use Sonys XDCAM Transfer-Tool to import the files from disk. So they are no longer nativ.
I tried another way and converted them into prores, but i have similar problems.
Eddie McFly
on Jul 13, 2011 at 11:51:17 pm
do you have any other apps running? what kind of drive are you using to play the media?
