New Sony FDR-AX1
COW Forums : Apple Final Cut Pro X Debates
Carlo Ferraro
New Sony FDR-AX1
on Oct 17, 2013 at 2:45:27 am
Does anyone know if FCPX can handle the codec for the above 4k camcorder?
XAVC S format, MPEG4-AVC/H264
If yes, would it be the wisest thing to convert to AppleProRes HQ?
Imac 27 Quad 3.4, 16GB Ram, 2GB Graphics, 6GB USB3.0 & Esata Raids
http://www.ferrarofilmsau.com
Jeremy Garchow
Re: New Sony FDR-AX1
on Oct 17, 2013 at 2:36:39 pm
My guess is that you'd have the choice of either rewrapping to h264, or optimizing to ProRes SQ (not HQ).
I like to optimize h264 material, but you don't have to.
I have also never worked with that camera before so you'd have to test it out and weigh the pros and cons of transcoding vs rewrap.
chris king
on Apr 13, 2015 at 7:58:05 am
The XAVC S video included in FDR-AX1 is not compatible with Final Cut Pro. Apple does not respond on these forums and no one here knows or can say when, if ever, XVAC-S will be natively supported by FCP X. So, is there any workaround to resolve the issue? Well, you just need to convert Sony FDR-AX1 videos to FCP most compatible Apple ProRes codec for native importing and editing.
