FCP X Audio Drop-Out or Audio Gap on Timeline.
COW Forums : Apple Final Cut Pro X Debates
Reggie Braydon
on Oct 1, 2013 at 8:19:02 pm
Hello fellow FCPX-ers.
I am posting this thread on a few forums as I have encountered a very weird issue taking place.
Trying to figure out if the issue I am encountering is a bug/glitch or a technical issue.
This has consistently occurred in three different projects now all shot at different times. The audio has been fine on the camera during the recording process and has been fine in it’s RAW NATIVE SOURCE.
THE ISSUE
For some reason my audio keeps dropping out on my timeline and it is creating audio skips/clicks making it impossible to export proper audio or fix the gaps on the timeline.
Screenshots are attached to this thread for a visualization example.
I have followed the process and finished troubleshooting with it all the way to FCP X.
Thus, I am able to pinpoint that whatever is going on is a FCP X issue
The audio is fine until it reaches the FCP X timeline.
I have tested the RAW FILE in VLC player and there is no audio drop-outs
I have also tested the video file in Sony Vegas Video and the audio is fine.
The Digital Workflow:
It start’s off as a .M2T file which is then run through Clipwrap 2.6.4 as a (rewrap as source format) and then eventually makes it into FCP X and is placed on the appropriate timeline.
I have had this same error for three different projects now. It has occurred both when using the NATIVE VIDEO FORMAT and when trying to use the (rewrap 1920 x 1080 format)
Thanks in advance for your time and help.
reggie-
Andy Neil
Re: FCP X Audio Drop-Out or Audio Gap on Timeline.
on Oct 1, 2013 at 10:07:13 pm
Is it possible that your audio format is of a non-standard nature like AAC or something? It sounds like the audio codec is not fully supported in FCPX.
Andy
http://www.timesavertutorials.com
Jeremy Garchow
on Oct 2, 2013 at 2:04:06 am
Quit fcpx, and trash your render files as well as peaks data.
