Keyboard shortcut for selecting clips outside primary
COW Forums : Apple Final Cut Pro X Debates
Stephen Nahroniak
on Jul 25, 2013 at 4:03:37 pm
I know "C" is the shortcut to select a clip. Anyone know the keyboard shortcut to select the clip thats above or below the primary storyline?
thanks
Andy Neil
Re: Keyboard shortcut for selecting clips outside primary
on Jul 25, 2013 at 5:02:11 pm
There isn't one. You need to hover with the cursor and use C or X. Send feedback to apple via the Final Cut Pro menu. it's something we should definitely have, even if it's just using the arrow keys to jump the "select" box to another clip.
Andy
http://www.timesavertutorials.com
Stephen Nahroniak
on Jul 25, 2013 at 5:08:33 pm
Bummer. I also notice there is no keyboard shortcut to nudge clips by frame inside the the viewer.
Andy Neil
on Jul 25, 2013 at 5:12:36 pm
[Stephen Nahroniak] "I also notice there is no keyboard shortcut to nudge clips by frame inside the the viewer."
Not sure what you mean by this. You can nudge clips frame by frame by selecting them in the event browser and using the left and right arrow keys to advance one frame forward or backward in the clip.
The viewer itself doesn't have a scrubber, but that's just the way the program works. You scrub the filmstrip in the event browser to view the video in the viewer.
Maybe I just don't understand what specifically you're trying to do in X.
Andy
Ronny Courtens
on Jul 25, 2013 at 5:18:36 pm
If you mean nudging in the Timeline:
Nudge 1 frame to the left: ,
Nudge 1 frame to the right: :
This is on a French keyboard.
Stephen Nahroniak
on Jul 25, 2013 at 5:18:48 pm
Sorry if I wasn't clear.
In 7 you could move a particular element that was in the canvas pixel by pixel by selecting it in the canvas and use the option+left arrow keys. It makes it more precise than using the mouse to move elements in the canvas sometimes. I haven't found that you can do that in X yet.
Mark Dobson
on Jul 25, 2013 at 5:21:10 pm
[Stephen Nahroniak] ". I haven't found that you can do that in X yet."
Sutre you can.
If you highlight any parameter in the inspector you can then nudge nudge wink wink to your delight
I use the arrows for multitude of detailed adjustment particularly in the transform window and the color board
Stephen Nahroniak
on Jul 25, 2013 at 5:30:16 pm
Hmm
So select the clip in the timeline to load it into the viewer
Highlight the parameter I want to change, lets say transform.
When I use the arrows, all it does is move the playhead left or right in the timeline
Ronny Courtens
on Jul 25, 2013 at 5:30:24 pm
As Mark says.
Highlight the parameter in the Inspector (click on its value) and use the Up and Down arrows to nudge.
OPTION+Up or Down arrows will increase or decrease the parameter by exactly 1 pixel.
Stephen Nahroniak
on Jul 25, 2013 at 5:31:11 pm
Great! Thank you
Neil Sinclair
on Jul 25, 2013 at 5:45:41 pm
..and SHIFT+ Arrow moves 10 pixels!
Ronny Courtens
on Jul 25, 2013 at 6:03:58 pm
Indeed.
Arrow = 1 px
Shift+Arrow = 10 px
Option+Arrow= 0.1 px
