Logo over white background?
COW Forums : Apple Final Cut Pro X Debates
Sean Lennon
on Jul 23, 2013 at 9:28:01 pm
Hi guys, I'm trying to create a white background to place a logo over in FCPX, when i place the logo clip over the background it removes the background and vice versa, any tips here?
The logo is a clip that I dragged to the storyline and resized and added some text to as a connected clip.
S
Bill Davis
Re: Logo over white background?
on Jul 23, 2013 at 10:19:44 pm
There's a Generator to create a white clip.
Put that on the Primary or connect the solid white as a Secondary.
Attach the logo as a Secondary or as a connected clip. Drag a filter onto the logo that will key it. You need there to be a "difference" between the logo and the background for keying to work. Either a difference in color (chroma key) or a difference in brightness (luma key)
When you apply the key to the Logo - it should "knock out" the alpha channel (whatever you selected as the luma or chroma material.) leaving the logo floating over the white background.
If you want to make a compound of the logo plus white, that's fine. Or leave them as separate layers - up to you.
The essential element is that the KEY filter is applied to the foreground clip to allow the white background to show through.
Hope that helps.
Know someone who teaches video editing in elementary school, high school or college? Tell them to check out http://www.StartEditingNow.com - video editing curriculum complete with licensed practice content.
Sean Lennon
on Jul 24, 2013 at 9:47:56 am
Hey great response thanks, but where do I find the filter?
Sean Lennon
on Jul 24, 2013 at 10:06:31 am
The background on the Logo is white also, I thought that if I matched the whites of the white background and the logo background it would work but now the text wont show up.
Mark Dobson
on Jul 24, 2013 at 11:08:22 am
Suggest you repost your problem on FCPX Techniques Forum - You'll get a better response.
