Converting MXF files shot on Sony F65 to MOV
COW Forums : Apple Final Cut Pro X Debates
Charles Ford
on May 30, 2013 at 5:59:22 pm
I have been given MXF files that were shot on a Sony F65. Each .mxf file is in its own folder which contains a .sum and a .xml file. I have been trying to convert these files to .mov in order to edit with FCP. Every conversion attempt fails because the files cannot be recognized. I have tried AVCHD Converter and Brorsoft MXF Converter. Nothing works. Does anyone have a suggestion?
Jari Innanen
Re: Converting MXF files shot on Sony F65 to MOV
on May 30, 2013 at 6:41:35 pm
Have tried the plugin?
http://www.sonycreativesoftware.com/srpm-10
Bret Williams
on May 30, 2013 at 7:32:16 pm
X had no problem with the F55. Do you have 10.0.8? And you also have to have the Sony plugin.
