FCPX project gone!?
COW Forums : Apple Final Cut Pro X Debates
joe mordecai
FCPX project gone!?
on May 6, 2013 at 2:31:52 pm
Hey all -
Please direct me to elsewhere if this issue has been posted before, but I've just had a little heart attack moment.
I've been working on an edit with FCPX, using the 10.0.8 Trial Version with a client to see if it's a viable way forward. I was up very late working on a project. Namely, had a lot of clips trimmed and arranged into the timeline. Closed the program as normal and went to bed. I woke up this morning, opened the project, and everything is GONE in the timeline.
All of my event info, in/out ranges, data is still there, but my timeline is empty. It's like it erased the whole thing. Now I have to start over?? Other past projects are still fine... but this one...magically gone.
Very upset... anyone have this happen?
Bret Williams
Re: FCPX project gone!?
on May 6, 2013 at 3:02:53 pm
Does the project not exist or are all the edits within the project gone? If the latter... Undo undo undo
joe mordecai
on May 6, 2013 at 3:10:32 pm
The project exists, but the timeline where all my cuts were was totally empty. Are there an infinite amount of Undo's? I've already started rebuilding what I had done yesterday... but is that "undo" method viable?
Russ Haskell
on May 6, 2013 at 3:40:37 pm
It's possible the backup file is still intact (if it hasn't been over-written this AM). With FCP closed, in the Finder, navigate to your project folder >Backups and move the backup to the same folder level as CurrentVersion.fcpproject. Hide the old one in a temp folder. Launch FCP and see whether your sequence returns.
Russ
Russ Haskell
on May 6, 2013 at 4:01:45 pm
Forgot to add that the backup file, which has a timestamp as its file name, needs to be re-named to CurrentVersion.fcpproject,
Sorry about the missing step.
Russ
joe mordecai
on May 6, 2013 at 6:57:48 pm
Thanks for the advice, Russ. I manually rebuilt my timeline... but if this happens again... I'll keep this in mind!
Bill Davis
on May 7, 2013 at 12:30:35 am
Sorry to come to this late - and it's probably not the issue,
BUT.
I sometimes see people hitting "new Compound" and not putting anything in them. If you were to do that and launch it, you can get what looks like a blank timeline replacing your populated one.
Did you check the upper left area right below the Favorite/Reject keyword HUD to see if your timeline history was still set to your main edit?
Just a possibility.
Know someone who teaches video editing in elementary school, high school or college? Tell them to check out http://www.StartEditingNow.com - video editing curriculum complete with licensed practice content.
