FCP7 Sequence... How To Open In Both FCPX and Premiere Pro?
COW Forums : Apple Final Cut Pro X Debates
Jona Taylor
on Mar 22, 2013 at 7:59:32 pm
Hello Folks... sorry if this repeats... I'm currently searching for the correct info and thought it smart to post here as well.
My 2008 Macbook Pro died (logic board). It was connected through eSATA to a 5 bay enclosure and I was organizing and beginning the edit (FPC7) on a film that I shot in India over the past 4 years.
I've bought a new Macbook Pro 2.7Ghz (OS 10.8.3) but it will not let me instal FCP7 (dmg) so I can not open the previous FCP projects.
I have FCPX installed but it won't open the previous FCP sequences. I also have CS6 installed. I want to try both programs to get a feel for them and then select one as my standard.
Would someone kindly chime in here and help point the way so that I can continue with this wonderful (and frustrating ;)) process?
Looking forward... :)
Jona
Shane Ross
Re: FCP7 Sequence... How To Open In Both FCPX and Premiere Pro?
on Mar 22, 2013 at 8:08:00 pm
Well, to get a project from FCP 7 to FCX you need 7toX from intelligentassistance.com
http://www.philiphodgetts.com/2012/01/7tox-for-final-cut-pro/
To get from FCP to PPro CS6, export an XML and import that XML in CS6
Shane
Little Frog Post
Jona Taylor
on Mar 22, 2013 at 8:15:08 pm
Wonderful Shane!
One more question? Suppose I used a friend's mac (FCP6-7) to export my FCP7 sequence as an XML... would FCPX be able to read it?
Huge thanks :)
Best regards,
Jona
Shane Ross
on Mar 22, 2013 at 8:17:34 pm
No. FCX cannot import a project or sequence from FCP without 7toX.
Period.
End of line.
Shane
Little Frog Post
Jona Taylor
on Mar 22, 2013 at 8:22:05 pm
Crazy that Apple would do this... it's like giving their supporters the finger.
Really appreciatie your assistance :)
Jona
Chris Harlan
on Mar 23, 2013 at 10:01:33 pm
[Jona Taylor] "Crazy that Apple would do this... it's like giving their supporters the finger.
Jona
That thought has wafted through many a brain over the last two years.
Michael Gissing
on Mar 24, 2013 at 11:43:12 am
Treat them mean, make them keen - obviously works.
Charlie Austin
on Mar 22, 2013 at 8:18:36 pm
nevermind... :-)
Jona Taylor
on Mar 22, 2013 at 8:31:33 pm
"Good new and bad news. The good news is that you can easily do what Shane points out above. The bad news is that you need to open the project in FCP 7 to export the XML that's necessary for either importing to Pr or using 7toX to get it into X. You don't need the media online to do it, perhaps you have a friend who could open the project and export XML for the sequence(s) you'd like to open?"
Hey Charlie (Shane)
So then I actually have to find a Mac with FCP7 on it so that I can open my project and export an XML file. Correct?
My friend is running FCP6. Will this work?
@Neil
I'm not sure why either. I think I have read that my Mac's HDD would have to partitioned to run both FCP7 and FCPX on the same Mac. When I go to instal FCP7 the little FCP box is greyed-out. FCPX and PP6 is already on the system.
Jona
Charlie Austin
on Mar 22, 2013 at 8:38:54 pm
[Jona Taylor] "Hey Charlie (Shane)
@Neil
6 won't work, since your project is newer (7) it won't open. You don't need to partition, they just can't both run at the same time. I'm not sure why you can't install either, i just installed 7 on a brand new machine. I used a new FCP studio (FCP 7.0.3) install DVD though. I read somewhere that some of the older installers used PPC code, and that won't work on OS X lion and above. :-(
~"It is a poor craftsman who blames his tools."~
~"The function you just attempted is not yet implemented"~
Jona Taylor
on Mar 22, 2013 at 8:59:33 pm
@Neil
"I used a new FCP studio (FCP 7.0.3) install DVD though."
- Yes, and I... I continue wrestling with these silly dmg files now that my new Macbook does not have a DVD burner.
As I don't have a concrete answer yet, I am just going to assume that I need FCP7 to export an XML file so that I can use: http://assistedediting.intelligentassistance.com/7toX/ to get the file to FCPX. Would still like to know this for sure if anyone can say for sure.
Very much appreciate you chiming in here :)
Jona
Charlie Austin
on Mar 22, 2013 at 9:00:43 pm
[Jona Taylor] "As I don't have a concrete answer yet, I am just going to assume that I need FCP7 to export an XML file so that I can use: http://assistedediting.intelligentassistance.com/7toX/ to get the file to FCPX. Would still like to know this for sure if anyone can say for sure."
Yes. For sure. :-)
Jona Taylor
on Mar 22, 2013 at 9:02:24 pm
Thanks Charlie! :)
Charlie Austin
on Mar 22, 2013 at 9:04:30 pm
[Jona Taylor] "Thanks Charlie! :)"
No problem. :-) FWIW, I'd invest in a USB Superdrive, especially if you have no other Mac's around to use disc sharing...
Also, assuming you've got a fairly complete sequence, when you open it in X or Pr, your head is going to explode. Since you own it, I'd see what I could do to get 7 installed so you can work, and then open it in X or Pr to get used to them first.
Jona Taylor
on Mar 22, 2013 at 11:08:09 pm
Absolutely will do Charlie. Thanks for the tip.
I wonder... if anyone knows if the FCP7 dmg would instal after some kind of file structure (folder) modification... as a work around?
Jona
Charlie Austin
on Mar 23, 2013 at 12:50:08 am
[Jona Taylor] "Absolutely will do Charlie. Thanks for the tip.
Can you mount the dmg? If so, is there a file somewhere on it (in a folder or something) with the extension .mpkg? the "install final cut" thing might not run, but if you can find the actual installer (the mpkg thing) maybe it will run? Just a random thought which may be completely wrong....
edit: I am wrong... are you sure the installer you ave is for final cut 7? Because the FCS 2 (FCP 6) installer won't work at all, but the FCS 3 (final cut 7) installer will. Maybe you updated to 7 somewhere along the line but have an installer for 6? You can install an update version of 7 as long as you have your *original* serial # as well as the one for the updater. Good luck! :-)
Jeremy Garchow
on Mar 23, 2013 at 3:49:37 am
[Jona Taylor] "When I go to instal FCP7 the little FCP box is greyed-out."
Because you already have FCPX.
See here: http://support.apple.com/kb/HT4722
Jeremy
Neil Goodman
on Mar 22, 2013 at 8:27:32 pm
im more curious as to why you cant install FCP 7on 10.8.3 if you have the software?
Neil Goodman: Editor of New Media Production - NBC/Universal
Jona Taylor
on Mar 23, 2013 at 2:20:24 am
I'm going to burn FCP7 as a disc image onto an small external drive and see if that will behave as a DVD.
Maybe I can install it from that?
Jona
Bret Williams
on Mar 23, 2013 at 3:59:56 am
You already have an app by the same name. The answer if I remember correctly is to simply put FCP X in a folder. That's it. Then install FCP 7 to your hearts delight. Then, put FCP 7 and all it's apps in a folder called Final Cut Studio and put FCP X back in the main Applications folder. It'll all work just fine after that, with the exception of sending to motion wonkiness. If you're in a position that you want to do that, you'll have to move X into a folder, and put the FC Studio suite back in the main app folder.
It sure as hell is a lot simpler than all this partitioning business or having a different boot drive, etc.
Jona Taylor
on Mar 23, 2013 at 4:18:31 am
I've said it before... Creative Cow has an incredible wealth of tallent!!!
Bret... you my friend are a STAR!!! Perfect well articulated answer. It's been 2 weeks of down time since this crash and now I'm finally back on track.
Wishing you all the happiness and success in the world :)
Jona
Jeremy Garchow
on Mar 23, 2013 at 4:20:09 am
FYI.
After the first entry of the link posted (which says to partition the drive), it tells you exactly how to do it, including how to modify the correct permissions.
Jeremy
Jona Taylor
on Mar 23, 2013 at 4:24:16 am
Huge thanks as well Jeremy! :)
I'll keep your partition suggestion guidance in mind in the event that I start having conflict on my system.
Best wishes and have a wonderful weekend... I know I will!
Jona
Jeremy Garchow
on Mar 23, 2013 at 4:27:06 am
[Jona Taylor] "I'll keep your partition suggestion guidance in mind in the event that I start having conflict on my system."
Partitioning is just the fist suggestion. Move past it.
The other suggestions are on how to install all of the applications if you can't partition. It's worth reading.
Jeremy
