Show events
COW Forums : Apple Final Cut Pro X Debates
Brian Abbott
Show events
on Mar 9, 2013 at 6:40:24 pm
I hit some command accidently and hid my events. Do you know how to show them again?
Also any documentation on commands would be incredible. The Internet seems to know very little about this program.
Patrice Freymond
Re: Show events
on Mar 9, 2013 at 7:53:03 pm
Did you hit CMD-SHIFT-1 ? That would hide the Event library...
As for a document on the commands how about the ... manual ? Chapter 17 starting at page 438 lists all the shortcuts and comments.
The manual is a searcheable pdf, so no great effort required there...
just my 2 cents
Patrice
Jari Innanen
Re: Show events
on Mar 9, 2013 at 8:02:42 pm
Menu -> Window -> Show Event Library. The shortcut is: Shift-cmd-1. You can also use the Help menu in FCP X for these kind of problems.
Jeremy Garchow
Re: Show events
on Mar 10, 2013 at 3:19:20 pm
Command-option-k opens the 'mission control' panel of fcpx.
Mess around with it. It's awesome.
It has commands by key, you can also search through by task ("editing" etc).
You can create new command sets or restore defaults.
Brian Abbott
Re: Show events
on Mar 10, 2013 at 3:21:33 pm
Thanks will try and memorize that one.
