External thuderbolt drive
COW Forums : Apple Final Cut Pro X Debates
Rob McLain
on Feb 27, 2013 at 2:23:09 pm
Thinking of getting this drive for my FCPX media drive on my iMac. Anyone else using this drive?
http://store.apple.com/us/product/HA480VC/A/buffalo-500gb-ministation-thund...
Would buy from a cheaper source of course. Not sure if this drive is 5400 or 7200 in speed. Am I going to notice a difference in speed if is 5400, or will the speed of thunderbolt kind of make it a wash?
Bret Williams
Re: External thuderbolt drive
on Feb 27, 2013 at 3:11:43 pm
It's small. It's expensive. It's likely 5400. It doesn't have pass-through thunderbolt. I wouldn't stop looking yet.
Gary Huff
on Feb 27, 2013 at 3:21:58 pm
Yeah, the Seagate drives with the Thunderbolt add-on adapter will be the same price, and you still have the add-on adapter.
I don't think you'll find any portable drives with TB pass-through at this time, so I wouldn't worry about that.
Paul Neumann
on Feb 27, 2013 at 3:27:55 pm
Read the reviews on Other World Computing. People say they run real hot and not as fast as advertised. It is 5400 rpm and you can pick it up there for $170 if you're so inclined. I use a Seagate 7200 with their adapter and it's pretty solid.
Lance Bachelder
on Feb 27, 2013 at 6:50:58 pm
If your just using a single drive than 7200 is going to be important. I opted for the G DRIVE because the newer model has USB 3 which is still overkill for a single drive. You don't really get any benefit using Thunderbolt unless you're attaching RAID storage that can take advantage of the huge bandwidth.
http://www.g-technology.com/products/g-drive.cfm
Lance Bachelder
Writer, Editor, Director
Downtown Long Beach, California
http://www.imdb.com/name/nm1680680/?ref_=fn_al_nm_1
Richard Cardonna
on Feb 27, 2013 at 8:41:40 pm
This dual drive 3.0 usb from g technology drive will be available shortly
http://www.bhphotovideo.com/c/product/893269-REG/G_Technology_0g02484_4TB_G...
G drive thunderbolt
http://www.bhphotovideo.com/c/product/858457-REG/G_Technology_0G02289_G_Rai...
Or lacie thunderbolt 2 drive:
http://www.bhphotovideo.com/c/product/845787-REG/LaCie_9000191_2BIG_2_BAY_4...
There are other thunderbolt drives availble at the BH
Richard
p.s. Next year usb 3.00 will be upgraded to 10,000 mbs just about where Thunderbolt is now.
Paul Neumann
on Feb 27, 2013 at 9:44:51 pm
Yeah, I have a 4TB G-RAID at the office and use the GoFlex with the adapter when I'm out in the field. I've only had one problem with the Seagate set-up and that was when the TB cable burned up. The drive just stopped working mid edit and when I went to check the connection the cable was really hot. So I stopped by the Apple store the next day and asked them to check it. They did, and it was bad and they gave me a new one. They told me it was best to use a 1m length with the Seagate stuff. I said, great give me a 1m one then. They said they don't make a 1m but Belkin does. I said, so what do I do if this burns up again? They said bring it back and they'll give me a new one. Great business model.
Craig Seeman
on Feb 27, 2013 at 9:53:46 pm
[Paul Neumann] "They said they don't make a 1m but Belkin does. I said, so what do I do if this burns up again? They said bring it back and they'll give me a new one. Great business model."
Given all the person in the store can do is replace it, that he's willing to keep doing it until Apple resolves it, is good.
And it seems Apple resolved it .5m Thunderbolt cable.
http://store.apple.com/us/product/MD862ZM/A/apple-thunderbolt-cable-05-m?fn...
Paul Neumann
on Feb 28, 2013 at 4:38:31 am
Oh I was more than happy with what they did. Didn't even have a receipt. Didn't really even get asked any questions. They immediately checked it and went and got me a new one. Couldn't be happier. But they were aware that it would probably go bad and just had to shrug as to why they didn't have the length that was best.
Craig Seeman
on Feb 28, 2013 at 5:15:20 am
[Paul Neumann] "and just had to shrug as to why they didn't have the length that was best."
Apparently Apple got the message.
Tony Brittan
on Feb 28, 2013 at 2:29:34 pm
Check out the LaCie thunderbolt eSATA hub! $200 and it allows for two eSATA drives connected at a time. You can pick up a GRAID 4tb for about $250. And single 1tb externals of good quality eSATA for about $100. ESATA has always been the go to before TB and you likely have a few you've been using.
I've got one and I love it! Very fast and works flawlessly. Until those TB drives come down in cost, this is great and allows you to use drives you've already got.
My 2 cents.
Tony Brittan
Island Shore Productions
Kill Devil Hills, NC
Bret Williams
on Feb 28, 2013 at 5:37:25 pm
Have you seen this? http://www.amazon.com/gp/product/B003EMJ34U/ref=ox_sc_act_title_2?ie=UTF8&p...
Simple USB 3 to eSATA adapter. As both max out at about the same speed 300MB/sec, it should work just fine if you have a new mac with USB 3.
I looked at getting the adapters and using my old eSATA drives when I got a TB mac, but decided to bite the bullet and go for a better RAID 5 storage solution. Got the Pegasus R4 with 8 terabytes. But it'll cost you! My iMac doesn't have USB 3. But it does have FW800, which at only 70MB/sec is still enough to playback multiple streams of 1080i ProRess 422 in RT. I had to use my old GRaid the other day on a project and it worked just fine connected via FW800. Not quite at snappy as the Pegasus which I can count on for 200+MB/sec. I swear it used to be even faster, but maybe getting full / fragmented.
