How to ungroup a multi-clip in the timeline?
COW Forums : Apple Final Cut Pro X Debates
David Powell
on Jan 31, 2013 at 9:31:19 pm
For the reason that I lose optical flow options with grouped clips and there is no way to match frame to an original clip (a real sore point for me about this program)so as to overwrite/connect it back over the multiclip.
Darren Roark
Re: How to ungroup a multi-clip in the timeline?
on Feb 1, 2013 at 12:31:49 am
I just ran into this issue myself when trying to export an XML to After Effects. It doesn't seemlike there is a way yet. This would be akin t I had to manually recut all of them.
This gets listed in the "Cons" section in my FCPX book.
Bret Williams
on Feb 1, 2013 at 1:00:41 am
You have to add stabilizing and such inside the angle viewer. You can match frame from in the angle viewer too. The bummer being that you can't enter the angle viewer and be parked on the frame you were on when you entered it. My workaround is to view the TC of the multiclip before entering the angle editor. f you have clip skimming on (cmd opt s) thats easy. Some stuff still needs a bit of polish for sure.
David Powell
on Feb 1, 2013 at 2:50:13 am
I was afraid you'd say that. Thanks for the responses guys.
