Remove attributes?
COW Forums : Apple Final Cut Pro X Debates
Elliot Pollaro
Remove attributes?
on Jan 16, 2013 at 9:10:55 pm
Just curious is there a remove attributes setting for the Audio? For example I have some clips that accidently had 10 limiters put on it.. I would like to just go in and select the clips and remove the audio effects from the clip. Is this possible?
Marcus Moore
Re: Remove attributes?
on Jan 16, 2013 at 10:14:22 pm
As far as I know, remove attributes doesn't exist yet.
Steve Connor
on Jan 16, 2013 at 10:31:26 pm
I take a clip with no filters and copy and paste attributes to clips that I want to remove filters from,
Steve Connor
'It's just my opinion, with an occasional fact thrown in for good measure"
Elliot Pollaro
on Jan 16, 2013 at 10:36:03 pm
That works with video, but it doesn't work with audio
Marcus Moore
on Jan 16, 2013 at 10:54:58 pm
I was going to say, I just tried that with an audio clip with a compressor/limiter on it and it just doubled up the effect.
Still, good to know it works for the video side of things...
Elliot Pollaro
on Jan 16, 2013 at 11:14:30 pm
Definitely need a solution for audio effects
Marcus Moore
on Jan 17, 2013 at 12:13:21 am
Probably not far behind. If it's anything like Legacy-- it's a shade on the same interface.
Jeremy Garchow
on Jan 17, 2013 at 3:12:32 am
If you select multiple clips and they all have the exact same filters, you can delete them en masse by selecting them all and deleting the offending filters.
All the filters must match, though, otherwise it gets buggy and inconsistent.
This function needs some help. Please tell Apple, pass it down.
Jeremy
Jeremy Garchow
on Jan 18, 2013 at 2:07:57 am
[Jeremy Garchow] "If you select multiple clips and they all have the exact same filters, you can delete them en masse by selecting them all and deleting the offending filters."
From the inspector.
Erik Lindahl
Re: move attributes?
on Jan 21, 2013 at 6:11:19 pm
Can't you do a match frame on the clip and do a replace / over write edit? Prior to doing this you could copy the clip if you need to paste any video-attributes back...
Not optimal but maybe a solution.
