10.0.06 issues part 2
COW Forums : Apple Final Cut Pro X Debates
Don Scioli
on Nov 1, 2012 at 9:34:13 pm
I am working on an 60 minute rough cut project to fine tune it and when I open it in FCPX as soon as I touch it with a mouse, I get the spinning beachball and the render menu sticks at "O". I don't see any corrupt files or anything and the project was fine when I finished the rough cut.
I cut and pasted the "event" to a new event "timeline" but the same thing occurs.
Any ideas?
many thanks
Marcus Moore
Re: 10.0.06 issues part 2
on Nov 1, 2012 at 9:54:07 pm
I'd start by deleting your project render files.
Also, any compound clips that originated in 10.0.5?
Oliver Peters
on Nov 2, 2012 at 12:12:54 am
I've run into this before in previous versions. It's the skimming. Park your cursor close to the top menu. Launch X and before doing anything, go up to the top menu and uncheck skimming. Exit and relaunch. Should be fine and then you can check skimming again. The app is still buggy in some areas.
- Oliver
Orlando, FL
http://www.oliverpeters.com
cem yildirim
on Nov 2, 2012 at 1:03:53 am
As a general rule, never update anything before you finish your project.
http://www.cemyildirim.i8.com
Don Scioli
on Nov 2, 2012 at 3:17:09 am
Thank you all- deleting the project render files seemed to do the trick...for now.
Gary Reynolds
on Nov 2, 2012 at 10:39:26 pm
I have 10.0.5 on one machine, and 10.0.6 on another I would like to have 6 on both but I am not finding an update????
