Things that are broken in Mountain Lion
COW Forums : Apple Final Cut Pro X Debates
Steve Connor
on Jul 29, 2012 at 5:32:42 pm
Live Type, for those of you who occasionally used it
Steve Connor
"The ripple command is just a workaround for not having a magnetic timelinel"
Adrenalin Television
Shane Ross
Re: Things that are broken in Mountain Lion
on Jul 29, 2012 at 10:53:31 pm
Livetype was discontinued before LION...integrated into Motion. So yeah, they aren't keeping that app in mind when they make new OS's
AGAIN...if you have a good, working system, why update? I only update when I am forced to. I mean, I just got LION up and running for Avid MC6...in May.
Shane
Little Frog Post
Steve Connor
on Jul 29, 2012 at 11:06:15 pm
I always clone my system drive and update that, then give it a few weeks to see if all is well.
So far so good with ML
Steve Connor
Bret Williams
on Jul 30, 2012 at 12:53:34 am
It wasnt integrated into Motion. When Motion came out, it included the libraries from LiveType. But you can't open a LiveType project with Motion, and there are features in LiveType, like extruded fonts that aren't in Motion.
Paul Jay
on Jul 30, 2012 at 7:54:00 am
Anyone that upgrades a perfect working system to a first version of a new os is always asking for troubles.
Rick Lang
on Jul 30, 2012 at 12:03:51 pm
I agree LiveType 2.1 refuses to load on my iMac, but I checked Soundtrack 1.5 and it loaded! I posted a note on Apple Discussions in the Mountain Lion group to see if anyone has any insight into a solution:
https://discussions.apple.com/thread/4157174
Rick Lang
iMac 27” 2.8GHz i7 16GB
Oliver Peters
on Jul 30, 2012 at 12:19:23 pm
I don't remember the specifics, but somewhere I read that ML gets rid of some more of the 32-bit legacy library files. LT probably needed these.
Oliver
Orlando, FL
http://www.oliverpeters.com
Rick Lang
on Jul 30, 2012 at 12:49:03 pm
I suspect this was a result of the new ProKit 7.3 in Mountain Lion even though it didn't break Soundtrack 1.5. Final Cut Express HD 3.5 still works too by the way. I don't use these any longer but always nice to have them working in case I wanted to revisit old material.
Rick Lang
Chuck Pelini
on Jul 30, 2012 at 2:54:31 pm
I upgraded to Mountain Lion and have no problems opening LiveType. I just revised a spot in which I used LiveType's glow effects on text and it opened fine.
Rick Lang
on Jul 31, 2012 at 4:25:09 am
Chuck Pelini:
"I upgraded to Mountain Lion and have no problems opening LiveType."
Very interesting. What machine is running you Mountain Lion?
Rick Lang
Rick Lang
on Jul 31, 2012 at 6:24:02 pm
Since I knew it worked for you, I tried to open it again today but did not elect to reopen the (unopened) window that was saved when I force quit it yesterday. Surprisingly, it came up fine with new windows today. So it must have been a glitch that has affected me and some other people on the first attempt at opening the application but after a shutdown I suppose it corrected itself.
Rick Lang
Chuck Pelini
on Aug 2, 2012 at 2:13:41 am
Glad it is working for you now. I rolled the dice and updated from 10.6 to 10.8 without doing a clean install. So far no problems except some of my PowerPC applications no longer being supported.
Mac Pro 2 x 2.26 GHz Quad-Core Intel Xeon
