Can FCPx Interpret Footage?
COW Forums : Apple Final Cut Pro X Debates
Ryan Walker
on Jun 22, 2011 at 9:01:16 pm
Does anyone know if FCPx can interpret footage like Premiere or After Effects? What if I want to take my 60p and interpret to 30p?
Thanks.
Jeremy Garchow
Re: Can FCPx Interpret Footage?
on Jun 22, 2011 at 11:00:43 pm
CinemaToolsX.
Oops doesn't exist. You can use compressor to slow down your footage.
Matthew Celia
on Jun 23, 2011 at 12:14:13 am
Yes, it will take footage shot in a different frame rate (say 60p) and if you drop it onto the 30p project, it will conform it. There is a menu option under the retime menu to do so as well I believe. I'm doing some tests and while some of the frame rate stuff I'm seeing is wonky, the scaling seems to be very good.
Ryan Walker
on Jun 23, 2011 at 5:55:32 am
Gotcha....but as of right now, there looks like no way to interpret a single clip without changing a timeline?
Jeremy Garchow
on Jun 23, 2011 at 1:55:45 pm
It doesn't work that way in FCP.
You want to conform your clip from 60 to 30 for slomo, right?
Todd Wolfe
on Jun 25, 2011 at 4:35:32 pm
FCPX does do it without cinema tools. "Conform Speed" will do it. I just did it with 60d 60fps footage and it worked great.
Ryan Walker
on Jun 25, 2011 at 4:48:40 pm
Awesome thank you! This was exactly the answer I was hoping to see.
Thanks.
