Bit rate confusion in mid flight
COW Forums : Apple Final Cut Pro X Debates
Donn Lawler
on Jun 19, 2012 at 3:14:38 pm
Hi gang!
So I ingested some footage for a friend to make DVDs of her Hi8 videos... The total time was around 5.5 hours so to get it all on DVD, I broke them up into five 1 hour projects in FCP X , then simply burned the projects to disc using the share option and the DVD set up... The first 2 burned fine, the third stalled out and gave me the message that the bit rate was too high... I attempted to successfully burn the fourth and fifth projects as well so it's just hanging up on the third project... And I can't for the life of me figure out why, as it was all captured at the same time using the same camera and the same settings! I must be looking at the problem form the wrong angle and wanted to share this along with a plea for help and suggestions as to why, for all intents and purposes, a series of clips in a project would not render to disc... Especially since said project came from the same captured media... Thanks in advance for any input! I really appreciate it.
