Audio Sync Issue
COW Forums : Apple Final Cut Pro X Debates
Marc Roberts
Audio Sync Issue
on Jun 22, 2011 at 4:56:15 pm
Anyone else having a problem syncing multiple clips using the sync audio option? If I sync one clip to one audio track everything is fine. If I try to sync 8 clips from camera a and 8 clips from camera b with an audio track, the resulting compound clip is a nonsynced mess. I have used pluraleyes in fcp 7 up to this point with no issues. Anyone find themselves with this particular problem? Any solutions you may have found? Thanks!
Marc Roberts
Eben Abbaan
Re: Audio Sync Issue
on Jun 22, 2011 at 5:46:09 pm
Hey Marc,
I'm having kind of a similar issue. I haven't played around with FCP X's audio syncing enough yet though... and I'm not familiar enough yet with the interface to chalk the sync failure up to anything other than 'user error' at this point.
EA
Loren Risker
on Jun 28, 2011 at 11:32:00 pm
I'm having a similar problem except with just one camera angle. I have 1 audio track and 5 clips. I suppose I can get around it by having 5 synced clips, but that seems silly.
