Getting plugins to work in 10.0.3 (calling Simon Ubsdell!)
COW Forums : Apple Final Cut Pro X Debates
John Mendelsohn
on Apr 21, 2012 at 2:46:49 pm
There are lots of plugins that won't work in the original version of the application, and require 10.0.3. So I downloaded Border and Drop Shadow V2, and a trial version of 10.0.3, and still no luck! In the Effects Browser, the icon is surrounded by a dark blue border. When I try to apply a drop shadow, I get...another thick blue border! Whaddaya!
Simon Ubsdell
Re: Getting plugins to work in 10.0.3 (calling Simon Ubsdell!)
on Apr 21, 2012 at 4:47:24 pm
Hi John
There is a default background which is set to blue but you can easily turn this off in the Inspector using the Background On/Off checkbox.
Incidentally if you don't want the border either just turn the widt parameter down to zero.
Probably should have made it without a background but there you go ... it was a very long time ago!
Simon Ubsdell
http://www.tokyo-uk.com
