10.0.3 Not Bad.
COW Forums : Apple Final Cut Pro X Debates
Neil Goodman
10.0.3 Not Bad.
on Feb 7, 2012 at 3:13:12 am
If only you could turn the angle viewer into an actual full timer viewer i might actually try something out in this thing.
Neil Goodman: Editor of New Media Production - NBC/Universal
Lance Bachelder
Re: 10.0.3 Not Bad.
on Feb 7, 2012 at 8:49:05 am
Yeah it's the same window as the scopes so obviously they could do it - would be great if was something that could be in the pulldown menu - so choices might be scopes, angles, viewer? And could easily be turned off?
Lance Bachelder
Writer, Editor, Director
Irvine, California
Ben Scott
Re: 10.0.3 Not Bad.
on Feb 7, 2012 at 10:14:03 am
would be even better if that was all possible on the 2nd display
Neil Goodman
Re: 10.0.3 Not Bad.
on Feb 7, 2012 at 4:20:34 pm
can you not use the scopes and all that one second display if you choose to move the viewer over there ? ive been putting the events on the second display, i like my canvas and timeline on the same display.
I think this release is definitely a step in the right direction but im still not really compelled to try and edit something in here. The 3 point editing into anything other than a primary track is along way off and i dont like how you have to enlarge or change the clip representation to see the audio thats attached etc and that the most minimal view w/o waveforms can be resized.
Hopefully 10.0.4 brings a viewer, and the option of tracks.
Lance Bachelder
Re: 10.0.3 Not Bad.
on Feb 7, 2012 at 9:31:57 pm
I keep the current viewer on my 2nd display which is a calibrated Dreamcolor attached via Display Port. I have had success color timing etc without using external. Only problem is scopes and now angle viewer split up that real estate which won't be a prob once I hook up one of my AJA devices.
Lance Bachelder
Irvine, California
Jim Giberti
Re: 10.0.3 Not Bad.
on Feb 17, 2012 at 1:01:25 am
[Neil Goodman] "If only you could turn the angle viewer into an actual full timer viewer i might actually try something out in this thing.
I'd definitely like to hear what you think if you do.
