Getting rid of compound clips after using 7toX
COW Forums : Apple Final Cut Pro X Debates
John Godwin
on Feb 3, 2012 at 10:47:06 pm
I think I read something here over the last couple of days about 7toX working well. But, because it brings FCP 7 timelines in as compound clips in the FCPX event, that becomes an issue with bloat when you put the compound clip into an FCPX project and start working with it.
I just had a chance to try this. I exported an xml of a timeline from FCP 7 and used 7toX to bring it into FCPX. Made 2 projects, placed the compound clip in one, and then opened the compound clip. Highlighted all the clips within it and Command-C to copy.
Opened the other timeline, er, sorry, project, and Command-V pasted. All the clips pasted perfectly but as uncompounded clips. Deleted the project with the compound clip in it. I deleted the original compound clip from the event to see what would happen and nothing did, just the compound clip deleted. I am left with the media in the event and a timeline with the clips uncompounded, as I wanted.
So this eliminates the problem of bloat if you just work with the compound clip.
Best,
John
Jeremy Garchow
Re: Getting rid of compound clips after using 7toX
on Feb 3, 2012 at 11:59:20 pm
I put the compound in the Project, select it an Break Apart (Command-option-g)
No more compound.
Jeremy
John Godwin
on Feb 4, 2012 at 12:51:33 am
Well, at least I found my elbow when I got there.
Best,
John
Jeremy Garchow
on Feb 4, 2012 at 1:01:01 am
[John Godwin] "Well, at least I found my elbow when I got there."
You could also "Open in Timeline" from the event and copy/paste that in to a Project.
Jeremy
