Eyedropper to match colour values
COW Forums : Apple Final Cut Pro X Debates
Matt Surf
on Jan 11, 2012 at 5:09:28 pm
Does anyone know where the eyedropper tool is in FCP X? I'm trying to match the colour of a logo with a solid colour from the generators menu but can't find anywhere to match the colours like in FCP7!
Thanks in advance
Matt
Mark Dobson
Re: Eyedropper to match colour values
on Jan 11, 2012 at 6:14:48 pm
[Matt Surf] "Hi,
Does anyone know where the eyedropper tool is in FCP X? I'm trying to match the colour of a logo with a solid colour from the generators menu but can't find anywhere to match the colours like in FCP7!"
Hi Matt
If you select the custom generator (it's black) from the generators and add it to the timeline - open the generator in inspector - in the published parameters there is a colour well - click on this and a colour display opens up - there is a 'magnify glass' picker there to allow to select a colour from anywhere on your screen.
hope that helps
Rafael Amador
on Jan 12, 2012 at 6:04:21 am
In your Mac OsX Utilities folder you have a wonderful "Digitalcolor Meter".
rafael
http://www.nagavideo.com
Mark Dobson
on Jan 12, 2012 at 2:39:08 pm
[Rafael Amador] "In your Mac OsX Utilities folder you have a wonderful "Digitalcolor Meter".
rafael"
Hi Raphael
Just wondering how you would be able to use the Digitalcolor Meter within FCPX?
Am I missing something?
Rafael Amador
on Jan 12, 2012 at 4:19:14 pm
The Digital meter gives you the RGB values, so you can set it manually in the generator.
I use the DCM often when working with Color that has no "Eye Dropper".
Is also interesting for because you can change the size of the picker and gives you the average of a group of pixels instead of just one.
rafael
Simon Ubsdell
on Jan 12, 2012 at 4:29:03 pm
[Rafael Amador] " The Digital meter gives you the RGB values, so you can set it manually in the generator.
I use the DCM often when working with Color that has no "Eye Dropper"."
Great tip, thanks! I never knew that existed - so useful!
Simon Ubsdell
Director/Editor/Writer
http://www.tokyo-uk.com
Matt Surf
on Jan 12, 2012 at 4:55:56 pm
Yeah, great tip!! I can't seem to add the exact values from the colour meter into the FCP X colour bars as it resets itself and also keeps disappearing off the screen but nonetheless, a great little find! Cheers
Martin Baker
on Jan 13, 2012 at 8:13:53 am
There's a preference in DCM to float its window over other apps.
Martin
Digital Heaven, London UK
Unique plug-ins and tools for Apple Pro Apps
FinalCutters - For Everything Final Cut Pro
Mark Dobson
on Jan 12, 2012 at 4:57:34 pm
Thanks Raphael
Matt Surf
on Jan 12, 2012 at 12:16:17 pm
Perfect - thank you!!
