Problem: Color distortion in Handling and Playback in FCP X
COW Forums : Apple Final Cut Pro X Debates
Edson Martins
on Jan 7, 2012 at 9:48:53 pm
Good Evening!
I installed the Final Cut Pro X with no problem. But after importing the videos (.Mov and ProRes codec) it's colors are altered, completely distorted of the original, both in playblack when handling.
These same videos, while in other editing programs or reproduction (imovie, quicktime ...) do not exhibit any change in color.
Someone tell me what happens?
I send a picture of what is happening.
Att Edson Martins
Oliver Peters
Re: Problem: Color distortion in Handling and Playback in FCP X
on Jan 7, 2012 at 10:48:51 pm
Make sure you disabled all the automatic import functions, like automatic color balance.
- Oliver
Orlando, FL
http://www.oliverpeters.com
Edson Martins
on Jan 7, 2012 at 11:08:32 pm
Thanks Oliver, but i already try this!
Do not work for me too.
Did you see the picture?
Tom Wolsky
on Jan 7, 2012 at 11:05:57 pm
Check to make sure ColorSync is correctly set.
All the best,
Tom
Class on Demand DVDs "Complete Training for FCP7," "Basic Training for FCS" and "Final Cut Express Made Easy"
Coming in 2012 "Complete Training for FCPX" from Class on Demand
"Final Cut Pro X for iMovie and Final Cut Express Users" from Focal Press
Edson Martins
on Jan 7, 2012 at 11:10:47 pm
Thanks Tom. So, how could I check this?
What is the correct set?
Tom Wolsky
on Jan 7, 2012 at 11:22:55 pm
Should be in Display in System Preferences. Use the default color setting and see if that helps, but it sounds as if you didn't change it.
You screenshot shows the project, but the image looks like the one in the browser. Very weird.
All the best,
Tom
Jeremy Garchow
on Jan 7, 2012 at 11:53:47 pm
Select that clip and open the inspector. Anything on that clip?
Where did you do the ProRes transcodes?
Craig Seeman
on Jan 8, 2012 at 4:49:12 pm
Since FCPX can handle the source files, import those directly and compare. If the source (H.264 .mov most likely) looks OK then it's something amiss with the ProRes encode.
Next, call up the Waveform scope (also might check Histogram) and see if the scopes match what you see vs what you believe it to be. If the scopes look good there's something about how you're displaying things (monitor). If the scopes show a "compressed" signal (raised blacks and or low whites) then it would be processing issue.
Test both the source and ProRes files in Quicktime 10 as well. That may let you know if the issue is specific to FCPX or a system issue.
