Magma Thunderbolt Expansion Chassis approved for Kona 3G/ATTO
COW Forums : Apple Final Cut Pro X Debates
Jeremy Garchow
on Jan 6, 2012 at 1:09:22 am
Heard on the @digitalreb Twitter feed.
http://www.magma.com/thunderbolt.asp
Jason Jenkins
Re: Magma Thunderbolt Expansion Chassis approved for Kona 3G/ATTO
on Jan 6, 2012 at 2:23:53 am
From the Magma site:
"External Graphics
There is an interoperability issue with MacOS using graphics (GPU) cards externally through Thunderbolt. Unfortunately, external graphics solutions for MacOS X do not work and we do not expect a resolution from Apple in the short term. We realize that external graphics support is a feature that many users want so we’ll let you know if this changes. For the time being our recommendation may be to run Windows using Boot Camp, but this is not yet confirmed as a working solution.
Jason Jenkins
Flowmotion Media
Video production... with style!
Check out my Mormon.org profile.
James Mortner
on Jan 6, 2012 at 10:29:16 am
Does this mean no I/O cards either ?
Frank Gothmann
on Jan 6, 2012 at 11:40:17 am
[James Mortner] "Does this mean no I/O cards either ?"
It probably means exactely what it meant for regualr pci expansion boxes in the past: some stuff will work, some won't, there will be issues, revised drivers, certain incompatibilities, reduced performance, etc. Which is why it was never really a 100 per cent statisfactory solution.
Enjoy!
Kevin Patrick
on Jan 6, 2012 at 1:39:30 pm
[Frank Gothmann] "some stuff will work, some won't, there will be issues, revised drivers, certain incompatibilities, reduced performance, etc."
Isn't how Windows boxes work?
(sorry, couldn't resist)
Frank Gothmann
on Jan 6, 2012 at 3:11:00 pm
[Kevin Patrick] "Isn't how Windows boxes work?
(sorry, couldn't resist)"
Spot on, Kevin. Of course with the exception of GPUs in a break-out box via Apple co-developed TB which will apparently only work with windows and won't work on OSX at all.
(Couldn't resist, either.)
Jeremy Garchow
on Jan 6, 2012 at 1:48:27 pm
James, did you read the link?
Kona 3G is ready.
Kevin Patrick
on Jan 6, 2012 at 1:58:21 pm
So products like the Kona 3G work. But external graphics don't. (or have issues that may not be resolved in the short term)
To me, that seems like it might not be possible to use a CUDA product for those who want to also use Adobe products. Or am I missing something?
Jeremy Garchow
on Jan 6, 2012 at 2:01:22 pm
[Kevin Patrick] "To me, that seems like it might not be possible to use a CUDA product for those who want to also use Adobe products. Or am I missing something?"
Right now the article says that a Kona 3G and a couple of SAS and fibre cards work.
The GPU limitation is an OSX problem with no fix in sight, accept to use bootcamp.
Ian Liuzzi-Fedun
on Jul 19, 2012 at 6:35:01 pm
Not entirely true as I can use a PCI Express expander to do this.
Mitch Ives
on Jan 6, 2012 at 5:50:13 pm
So the only AJA card that works is the 3G? If so, that won't help much...
Mitch Ives
Insight Productions Corp.
mitch@insightproductions.com
http://www.insightproductions.com
"Criticism may not be agreeable, but it is necessary. It fulfills the same function as pain in the human body. It calls attention to an unhealthy state of things." - Winston Churchill
Jeremy Garchow
on Jan 6, 2012 at 6:09:53 pm
[Mitch Ives] "So the only AJA card that works is the 3G? If so, that won't help much..."
Might be the only one listed/tested so far. The AJA drivers say that all of them are Thunderbolt aware since a few drivers ago.
Time will tell.
Mitch Ives
on Jan 6, 2012 at 6:19:46 pm
[Jeremy Garchow] "Might be the only one listed/tested so far. The AJA drivers say that all of them are Thunderbolt aware since a few drivers ago.
Time will tell."
I'm certainly hoping for that...
Mitch Ives
John Heagy
on Jan 8, 2012 at 2:15:11 am
Windows supports Thunderbolt better than OSX... priceless!
The fact that graphics cards are a no go in OSX via Thunderbolt gives me hope that a proper MacPro will be released.
John Heagy
