What's the current state of ProRes in the Windows world?
COW Forums : Apple Final Cut Pro X Debates
Chris Harlan
on Jan 4, 2012 at 9:48:37 pm
I'm thinking more seriously now about jumping from the Apple ship. One of my hesitations is the enormous amount of ProResHQ projects that are currently in my--and my client's--pipeline. Certainly, I'll keep all my Mac stuff going, but where are things, these days, with Windows and ProRes? And, for that matter, Media Composer, Windows and ProRes?
Frank Gothmann
Re: What's the current state of ProRes in the Windows world?
on Jan 4, 2012 at 10:02:06 pm
I haven't encountered any problems at all working with Prores in either MC 6.0 or Premiere CS5.5 on windows. Of course, it is decode only with these apps, but apart from that is really is no different at all compared to working with it on the Mac side. I export into DnxHD (or Cineform) on Windows.
Chris Harlan
on Jan 4, 2012 at 10:19:10 pm
[Frank Gothmann] "I haven't encountered any problems at all working with Prores in either MC 6.0 or Premiere CS5.5 on windows. "
Cool!
[Frank Gothmann] "Of course, it is decode only with these apps, but apart from that is really is no different at all compared to working with it on the Mac side. I export into DnxHD (or Cineform) on Windows."
Can I wrap ProRes in MXF on Windows, or do I need to transcode DNxHD back to ProRes on a Mac for clients who require ProRes delivery? And does transcoding still have bad gamma juju, or has that mostly been worked out?
Frank Gothmann
on Jan 4, 2012 at 11:03:55 pm
No re-wrapping to Prores on windows unfortunately.
As far as gamma is conerned, same as on the Mac side. Regular import = relateively slow and gamma shift (in my case length x 4). AMA, no gamma shift. Trancoding AMA file to DnxHD MXF via consolidate/trancode = very fast and NO gamma shift (in my case length x 0.8).
If you need to deliver Prores to your clients you could either encode the Dnx output on the Mac, or play-out on the AVID and capture on a Mac or Kipro or you can get Episode Engine for Windows and encode your Prores jobs on the windows side.
Yes, Engine costs a few bucks but you but you'll easily save that money with the hardware over a relatively short period of time.
Ty Wood
on Jan 13, 2012 at 9:20:07 pm
There's hope yet, though!
http://www.telestream.net/company/press/2011-03-31.htm
http://www.dvxuser.com/V6/showthread.php?269583-5DtoRGB-now-does-ProRes-enc...
No exporting directly to, but at least with the FlipFactory route (Server OS required) you have a transcode option for special deliveries.
Tony Hernandez
on Dec 9, 2012 at 8:29:43 pm
A new multi transcoder encoder for PC windows including export to Apple ProRes from any microsoft windows is available from now.
CINEC allow to encode video to prores 422 or 4444, DNxHD and XDCAM
Fast processing thanks to multicore support
Available at: http://www.cinemartin.com/cinec/
Tony Hernandez
Hardware & Software Technician
Colaborator of the Cinemartin pro. portable video recorders team
Sean Salzman
on Aug 1, 2013 at 12:34:06 am
Does Cinec Gold not support importing R3D files? I've tried this and it just doesn't work. Running windows 7 64 bit
