Compressor 4 (Not Responding) everytime I drag setting to a job
COW Forums : Apple Final Cut Pro X Debates
Ricardo Guerreiro
on Dec 5, 2011 at 6:50:45 am
So, everytime I drag a setting to a a job in Compressor 4 (either to a video sent from FCPX or just oppened directly on Compressor), the application becomes unresponssive or just nothing happens, that is, I drag the setting but nothing appears on the job. Anyone seen this? Solutions? Thanks.
Paul Jay
Re: Compressor 4 (Not Responding) everytime I drag setting to a job
on Dec 5, 2011 at 8:22:24 am
Reset background processes
Trash preferences
Ricardo Guerreiro
on Dec 5, 2011 at 9:15:30 am
Thanks Paul.
This was actually the first time I launched Compressor 4 and I never did anything to the preferences. Still did what you said but to no avail... didn't fix the problem.
Lemur Hayop
on Dec 5, 2011 at 8:45:32 pm
I have the exact same snafu as the OP. There doesn't appear to be any mention of this in the FCPX Techniques forum. Anyway, I use Export Movie (H.264) when Compressor screws up.
http://www.k9sound.com
Jim Giberti
on Dec 5, 2011 at 9:40:56 pm
Just had the same issue when doing a few versions of a project for output. I'm mastering everything to Pro Res and then just dragging those files to Compressor. I noticed that it took a few attempts to get the file to "stick". I simply repeated the task a few times and assumed it was my issue or a sluggish response from a lack of available RAM.
Liam Hall
on Dec 7, 2011 at 1:48:18 pm
Compressor 4 has completely stopped working for me and gone on holiday. Seems to be an issue with QMaster. I've tried trashing prefs, reinstalling etc, all to no avail.
It really is a piece of garbage...
Liam Hall
Director/DoP/Editor
http://www.liamhall.net
Michael Bernstein
on Aug 8, 2012 at 3:50:30 am
Liam (and all):
I've just downloaded Compressor 4.04 and am experiencing the same problem with the front end: the spinning beach ball and "Compressor not responding" every time I:
-Drag a setting to a job
-switch between jobs
Have you found any improvement or workaround?
Michael
Ricardo Guerreiro
on Aug 8, 2012 at 8:39:02 am
To tell the truh, I stopped using Compressor 4. For the amount of work I was doing, it sufficed to export using Compressor settings through FCPX. So, right now I'm not sure if it somehow is fixed but I never got back to trying it again.
Liam Hall
on Aug 9, 2012 at 6:02:48 pm
I gave up and started using Adobe Media Encoder. Then last month, I changed my system hard drive and reloaded all of the software including the operating system and bingo, it was back up and running.
Liam Hall
Director/DoP/Editor
