Compressor fails with Quick time Error -50
COW Forums : Apple Final Cut Pro X Debates
Tim Gillespie
on Nov 14, 2011 at 5:22:19 pm
Hi guys:
I have one particular Final Cut Pro X file that I cannot get compressor to process for Vimeo.
I have two files about the same kind. One outputs in about two minutes perfectly while the other one takes about 2 hours and fails with 10% to go.
The only clue it gives me is this error message. Failed: Quick Time Error: -50
Is there a way to look this up and find out what happened?
Is there a way for Final Cut Pro to check the file to make sure it is not corrupt? It plays nicely in FCPX.
I think Compressor is installed fine because other files export nicely.
Does anyone have any ideas?
Thank you.
MacBook Pro, Lion 10.7.2, all sortware is upgraded. 8 gb ram quad core processor. Stable system
Note: this post has also been posted at Apple Compressor Forum
Craig Seeman
Re: Compressor fails with Quick time Error -50
on Nov 14, 2011 at 8:04:15 pm
I'm not sure these error codes are relevant
http://support.apple.com/kb/HT1618
Why not just export to ProRes and bring that file in to Compressor? I've never been a fan of Send to Compressor feature as it's had a history of bugs and challenges.
