FCPX Export Strips Timecode?
COW Forums : Apple Final Cut Pro X Debates
Adrian Jebef
on Oct 13, 2011 at 7:38:32 pm
For some reason I didn't have this problem with FCPX 10.0 but in 10.1 all of a clips embedded timecode gets striped when I export directly or send off to compressor. Did I miss something here? Thoughts?
Jeremy Garchow
Re: FCPX Export Strips Timecode?
on Oct 13, 2011 at 8:28:58 pm
You mean the original timecode or sequence timecode?
Adrian Jebef
on Oct 13, 2011 at 8:44:13 pm
Original clip timecode. Embedded TC metadata.
Jeremy Garchow
on Oct 13, 2011 at 8:46:35 pm
[Adrian Jebef] "Original clip timecode. Embedded TC metadata."
And what exactly are you trying to do? Please be specific. If you are exporting more than one clip, the tc is of course going to change.
Adrian Jebef
on Oct 13, 2011 at 9:02:35 pm
I'm working with one file. Basically, doing a down and dirty color-correction or audio sync with one clip at a time and then trying to export or send to Compressor my changes while preserving original camera timecode.
Jeremy Garchow
on Oct 13, 2011 at 9:32:02 pm
[Adrian Jebef] "I'm working with one file. Basically, doing a down and dirty color-correction or audio sync with one clip at a time and then trying to export or send to Compressor my changes while preserving original camera timecode."
And you said this worked with FCPx.0? I can't imagine that it would.
Exporting will definitely change the tc, not sure about a send to.
I'll have to do some checking later. My first hunch is that it's not possible, but anything can happen.
