How to assign tracks and audio outputs on fcpx (to write back to xddisc)
COW Forums : Apple Final Cut Pro X Debates
jurriaan van der kamp
on Oct 13, 2011 at 2:06:32 pm
How export a project (the former sequence) directly back to a sony 530 xdcam? In FCP7 in order to
export a sequence to an xddisc i needed to change the audio sequence setting from dual mono to 8 outputs dual mono. After this step i had to ajust the overal audio level with -6 db. Now i could also chose that for example your general noice is on track one and your voice over is on track 2. How can i accomplice this with fcpx?
Re: How to assign tracks and audio outputs on fcpx (to write back to xddisc)
on Oct 14, 2011 at 1:01:25 pm
hallo,
Does nobody no this?! is this a pro forum?
John-Michael Seng-Wheeler
on Oct 17, 2011 at 4:12:36 pm
More like, wrong forum. Try posting again in the FCPX Techniques forum.
http://forums.creativecow.net/fcpxtechnique
JM
Christian Schumacher
on Oct 17, 2011 at 4:59:49 pm
[jurriaan van der kamp] "Does nobody no this?! is this a pro forum?"
No, you've got it backwards.
This forum is about figuring out if the software itself is. Literally.
on Oct 17, 2011 at 9:37:20 pm
thats deep Christian!
So i will try my luck at the techniques forum. So this forum is strictly opinion..?
