random digital glitch on audio after edit
COW Forums : Apple Final Cut Pro X Debates
Simon Woodgate
on Oct 11, 2011 at 10:20:16 pm
Hi all,
Long time fcp user (since V2 I believe) but mainly an audio guy logic / pro tools etc.
I have a repeatable problem with audio in FCPX. The first time I start playback on the timeline after changing an effect or title setting, I will invariably get an audio glitch, like a half second buzz, around 3-4 seconds into playback. Rewind and play again and it's all fine.
I'm also getting a few instances using the titling where FCPX forgets the font size! I add title, change size, preview fine, then it auto renders with a font size of 0!
anyone else getting these two problems at all?
Mark Morache
Re: random digital glitch on audio after edit
on Oct 11, 2011 at 11:35:49 pm
I'm curious, it this while it's background rendering? I often have playback problems with the background processing, even if it pauses the process while I playback.
I don't know about the font size changing. Is it possible you are adding a keyframe? If you reset the parameters, does it act as expected?
FCX. She tempts me, abuses me, beats me up, makes me feel worthless, then in the end she comes around, helps me get my work done, gives me hope and I can't stop thinking about her.
Mark Morache
Avid/Xpri/FCP7/FCX
Evening Magazine,Seattle, WA
http://fcpx.wordpress.com
